09-01-2023, 12:50 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Feb 2023
Best Clutch for single turbo LS3 setup
Trying to get a parts list together and wrap my head around the pricing. Gonna go with a single VSR 7875 turbo. I was looking into McLeod, and as with everything there are negatives out there. But, it seems I have found more positives than negatives with Monster Clutch. What are your guys recommendations/experiences. Should I be looking into something else for this setup? Thanks.
09-01-2023, 01:18 PM | #2 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
You're on the right path, most likely a twin-disc depending on how much RWHP you're targeting.
09-02-2023, 05:50 AM | #3 |
8.60 @ 157 @ 4200lbs
clutch
Mcleod, ACT, Monster, and so on, if installed correctly and shimed as needed. You wont have any problems, most issue people have and post are due to improper install,
Look up does your clutch setup need a shim, I believe Tick performance has a great writ up on it.
2010 camaro twin turbo 8.60 @ 157 full weight 4200
09-02-2023, 10:19 AM | #4 |
While you're in there and regardless of your clutch choice, make sure you go with a billet release bearing support.
09-02-2023, 01:00 PM | #5 |
And put a remote bleeder line in.
09-05-2023, 08:45 AM | #6 |
Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
Cheaper option (single disc) would be a Spec Stage 3 or Stage 3+ depending on the power level goals. It held fine 3 years 30K, 20K over 9XX WHP on 20PSI Stock Motor.
Better option will give you headroom to grow Monster Twin Disc. Will support more power. Will give you a stock pedal feel making drivability relatively easy depending on the set up. With that said either way you do it, get a new OEM GM Slave, Monster Billet Support Bearing, and Monster Remote Bleeder. For Reference I personally now have a Monster Triple Carbon in the car, but we are big power levels in comparison. I went straight to the triple instead of twin disc. |
09-05-2023, 10:07 AM | #7 | |
09-10-2023, 06:20 PM | #8 |
Drives: 2010 Chevy Camaro SS Join Date: Mar 2022
I have a single turbo setup, also using the vsr 78/75 2.5g, making around 14lbs right now and my mcleod rxt1200 seems very comfortable, smoked a regular rxt with it. +1 on upgrading to a billet support, and speed bleeder while there.
09-12-2023, 11:29 AM | #9 |
Drives: 2016 1SS Join Date: Apr 2012
The Mcleod RXT1200 Is a great option for your combination.
