08-06-2018, 10:39 PM | #15 | |
Boosted Moderator
I've torn up many thousands of dollars in parts along the way....
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
08-07-2018, 12:52 AM | #16 | ||
Drives: Miss Con Ception Join Date: Aug 2016
All that money you spent and you cheaped out on the new bolts? The way I saw it, I'm only going to do this once. The spec I have reads 74 lbft + 120° Where did you find 165 lbft? Quote:
At stock power I added inserts. The stiffer rear sway I bought has been in my garage for 5 years.
2011 1SS/RS LS3 CGM
08-07-2018, 08:14 AM | #17 | |
GPI Sales Consultant
In that thread he also talks about re-using the bolts being a non-issue. I'll let you guys know if I have to re-do anything or have a bolt failure. I expect zero issues.
Got a question about a GPI product? Feel free to shoot me a message! |
08-07-2018, 08:40 AM | #18 | |
2010 2SS/RS
08-07-2018, 08:40 AM | #19 | ||
I definitely agree. Not that i'm trying to go cheap, well sorta, but I like doing one mod at a time and with only headers intake tune, I think a good starting place is the bushings as mentioned here. The stamped steel parts and soft bushings I'm sure will eventually be a weak point. |
08-07-2018, 09:00 AM | #20 | |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
this....2 c'fests(1300 miles ea.) and countless hwy miles along with 100+ trips down the 1320....stock bolts re-used...zero probs.
08-14-2018, 06:30 PM | #21 | |
08-14-2018, 06:34 PM | #22 | |
08-15-2018, 04:53 PM | #23 | |
08-15-2018, 08:04 PM | #24 | |
Let me know how you like them!
08-16-2018, 10:36 AM | #25 | |
08-21-2018, 06:00 PM | #26 |
Hello again acammer, another quick question please, on the install of the NEW bushings, did you do them one at a time after you pushed the stock one out? Or did you press all the stockers out, then go back around to install the solid ones. Just curious as to the method and save some hassle hopefully. Thanks sir. They are going in Saturday..
08-21-2018, 06:10 PM | #27 | |
08-22-2018, 07:14 AM | #28 |
Thanks you sir very much, I appreciate it.. Have a good day !!
