Old 12-24-2012, 04:56 AM   #1
*_ERIC_*
OMINOUS
*_ERIC_*'s Avatar
Drives: '10 Camaro 2SS/RS M6
Need New Wheels HELP!!!!
Hey guys,
I'm looking for a set of 19x10.5 all the way around. Anyone know of manufacturers who produce these rims that aren't as expensive as Forgeline with the correct backspacing?
BTW what is the offset? I've been reading +27mm is optimum. Is that the same for the front and back?
I'd definitely go with Forgeline's but I don't want to spend that much money. Also, I'd probably be willing to do 20x10.5's all the way around if I can't find 19x10.5's.
Any help is appreciated, thanks!
*_ERIC_* is offline   Reply With Quote
Old 12-24-2012, 10:44 AM   #2
SPCBA
Drives: pleather and Chiclets
if you can find the answer I am curious as well. Also the offsets to get square on forgestar cf5
SPCBA is offline   Reply With Quote
Old 12-24-2012, 04:03 PM   #3
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
I'm pretty sure
the Pedders/Forgeline 19 X 10.5 wheel offsets are different front to rear.I have been trying to obtain them,but they seem to be TOP SECRET.
rockrau is offline   Reply With Quote
Old 12-24-2012, 07:48 PM   #4
SPCBA
They would have to be to get square. Wish people would share and more options became available.
Old 12-25-2012, 05:45 AM   #5
*_ERIC_*
OMINOUS
*_ERIC_*'s Avatar
The problem is, if they do, then they'll lose to the competition. It's a way to secure the market. Maybe someone who has the setup already could share the info. I'm sure it'd take no more than a machinists ruler, front and rear wheels to find out.
Old 12-25-2012, 05:48 AM   #6
supercharged zl1
supercharged zl1's Avatar
Drives: '13 camaro zl1 '08 daytona charger
id go with foose
supercharged zl1 is offline   Reply With Quote
Old 12-26-2012, 11:04 AM   #7
*_ERIC_*
OMINOUS
*_ERIC_*'s Avatar
Well, here it is. I looked up some VMR rims. I found their v710's are offered in 19x10 and 19x11 both with a +25mm offset. I just wonder if those will fit? The backspacing on the 19x10's will be approx. 6" which should be fine. The backspacing on the 19x11's will be approx. 6.50" which should also be fine. Now I'm curious to know how far they will stick out being that I have Air Lift. Will this cause problems?
