10-17-2022, 08:01 PM | #1 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
V6 1le front swaybar
The front swaybar on my v6 is straight where it go in front of the engine where the V8 bar is bent alot to get by the engine. Does the v6 1le use it's own front bar or a bar from a V8 ?
10-17-2022, 08:13 PM | #2 |
Drives: 2002 Z28, 2023 1LT RS Redline Join Date: Sep 2022
According to all the sources I have found the V6 1LE suspension consists of the same suspension components found on the base SS Camaro. Which apparently does not make much of a difference in terms of feel and handling. The real benefit came from the upgraded tire width and summer rubber.
10-17-2022, 08:39 PM | #3 |
The V8 front bar would look strange on v6. I know it is rarely seen. The v6 suspension is too sloppy and vague for me. Bilstein B6 dampers, summer tires and a sporty alignment has helped a lot. My next step would be swaybars. It would be nice to have a bigger front bar made for the v6 but I imagine gm just put the deformed v8 bar on front of the v6 1le.
10-17-2022, 11:25 PM | #4 |
Long hauler
10-18-2022, 05:52 AM | #5 |
Thank you sir. I was hoping they made a nice front bar just for the v6 1le. I quesss the crooked bar for the V8 works and fits good . Now I need to find the end links. We have those silly plastic ones.
