Old 06-21-2022, 12:47 PM   #29
paradigm
Drives: 2022 Camaro 1SS 1LE
Anymore suggestions on side skirts and rock guards?
Just to clarify, if I get the side skirts, I won't need rock guards?
2022 Camaro 1SS 1LE 6-speed
paradigm is offline   Reply With Quote
Old 06-21-2022, 01:08 PM   #30
MightyBobo
MightyBobo's Avatar
Drives: 2022 VOM 2SS 1LE M6 Camaro
The skirts won't do jack diddly to block rocks from flying up.
Strongly recommend getting the ACS rock guards with their skirts. I have them front and back, and not only are they fantastic at blocking rocks, but they also block most if not all water spray when going through little puddles and stuff.
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251) - ETA 20220223
20211120 - 1100 --- 20211207 - 2500
20211208 - 3000 (TPW: was 20220103, now 20220124)
20211220 - 3400 (TPW: 20220110)
20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle)
20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223)
20220212 - 4800 --- 20220216 - 6000!
2024 Silverado EV RST First Edition on reserve, as well.
MightyBobo is offline   Reply With Quote
Old 06-21-2022, 01:18 PM   #31
ZPirate
ZPirate's Avatar
Drives: 2023 Summit White Camaro ZL1 M6
In my opinion you need both on the 1LE. I have the ACS rock guards and side skirts on my car. So far they have worked great.
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver)
2003 Nissan 350Z (modified)
2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold)
2009 BMW 135i (Sold)
ZPirate is offline   Reply With Quote
Old 06-21-2022, 01:21 PM   #32
ZPirate
ZPirate's Avatar
Side skirts do help, especially keeping rocks thrown up by the front tires off the side of the car, but I agree, not as much as having both rock guards and side skirts. I'm all in on the ACS rock guards and side skirts too.
Old 06-21-2022, 01:38 PM   #33
MightyBobo
MightyBobo's Avatar
Originally Posted by ZPirate View Post
Side skirts do help, especially keeping rocks off thrown up by the front tires off the side of the car, but I agree, not as much as having both rock guards and side skirts. I'm all in on the ACS rock guards and side skirts too.
IMHO, if anything is hitting at all, they aren't helping. Just me, though. As you said, both is far superior.
Old 06-21-2022, 01:57 PM   #34
Coded4SS
Drives: 2020 1SS 1le
They do help, just not 100%
My previous GM guards were heavily pitted on the inside they were certainly helping. But i still had some chips. Both would be the best, plus some PPF on rear
Coded4SS is offline   Reply With Quote
Old 06-21-2022, 02:33 PM   #35
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Best Side Skirts????
Well for the money, the BEST side skirts are EOS ZL1 style. If you install them with RIVETS every 6 inches or so they will hold up fine (see pic below). I had a 100MPH off track incident with no visible damage. They cost roughly 400 dollars for the carbon fiber finish. The Carbon Fiber finish I would rate about a 7 on a 1 to 10 scale. Anderson or C7 BOTH probably have a little nicer finish . The FIT if you use the rivets on the EOS is excellent. Use plastic door edge guard material on the bottom edge of the sideskirt. This will protect the EDGES so that if they take a hit then that wont start the peeling away process that you sometimes see when carbon fiber is damaged on the edges. If you look closely at the pic you will see those edge guards installed in the sideskirts. I do the same thing on my EOS front splitter.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 06-21-2022, 09:13 PM   #36
Matt1LE
Matt1LE's Avatar
Drives: 2020 3LT Camaro 3.6L 1LE
Dumb question. Can you post a picture of the underside for the front of the side skirt? I want to see what it would take to modify it to work with the GM factory rock guards. I would need to cut off from the front of the skirt an inch to inch and a half to make it work. I want to see if it would be worth the effort as well as being functional.
Thanks
Matt1LE is offline   Reply With Quote
Old 06-21-2022, 09:50 PM   #37
sr71bb
sr71bb's Avatar
Thanks
Matt, I use the GM factory rock guards and you DO NOT have to cut the ends of the side skirts off. You take the rock guards OFF and you install side skirts and THEN you reinstall the rock guards over TOP of the sideskirts. Here is a picture below of mine. You use RIVETS to insure a tight fit. I used BLACK rivets on the rock guards so that they blend in. The way the rocker is shaped it actually fits better than you think it would. Look at the THIRD pic to see how it looks looking at the rocker towards the FRONT of the vehicle.
Retired Cars BELOW:
Old 06-22-2022, 10:48 AM   #38
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I bought a set of EOS side skirts off Walmart off all places. Definitely best bang for buck, even though I haven’t installed them lmao.
Came in Primer Black but definitely gonna get them painted properly before I install. Gonna use those rivet instructions so thanks for that!
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is offline   Reply With Quote
Old 06-22-2022, 02:33 PM   #39
MANNAXMAN
MANNAXMAN's Avatar
Drives: 2016 Camaro 2SS Convertible
Hard to tell from your pics, but did you only use rivets or did you also use double sided tape?
2016 Camaro 2SS, Convertible, Summit White, A8, NPP, NAV, Daily Driver (Sept. 2016-Present)
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 06-22-2022, 02:41 PM   #40
MightyBobo
MightyBobo's Avatar
Ive heard double sided tape ruins the tight fitment w/ the skirts. I only used rivets on mine.
Old 06-22-2022, 02:48 PM   #41
sr71bb
sr71bb's Avatar
Thanks
Here below are some additional pictures of what it looks like when you have BOTH the GM splash guards and the EOS rocker panels installed.
Retired Cars BELOW:
Old 06-22-2022, 02:51 PM   #42
sr71bb
sr71bb's Avatar
I did NOT use tape at all. ONLY rivets.. There are about 25 per each skirt. My opinion which is not shared by some is that you do not need the tape. The rivets will pull the skirt very tightly to the rocker panel if done properly.
Retired Cars BELOW:
