06-10-2022, 11:21 PM | #1 |
Drives: 23 2SS 1LE Join Date: Feb 2019
AFM Valve Question
I have a horrible rattle from my AFM valves that's progressively got worse. I have an aftermarket exhaust where I've replaced the muffler, resonator, and cats but I left the AFM valves. I do have AFM tuned out so they are not needed.
I'm going back to the exhaust shop unless I can do a fix myself. But my question is, which way is open and closed? Are they resting in the open position and when I push on them they close? Or vice versa. When the car is off I notice I can push them in (towards each other, the middle the car) but I don't know if that is opening or closing the valves. I don't want to accidentally force them shut.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
06-11-2022, 06:16 AM | #2 |
Long hauler
They rest closed
06-11-2022, 07:44 AM | #3 |
Thanks! I'll see if I can use something to hold them in.
06-11-2022, 10:22 PM | #4 |
Update: using zip ties somehow made it worse. On startup it was actually almost perfect and sounded great with hardly any rattle. Driving was much worse tho and had almost a constant rattle. Scheduling a shop to remove them soon.
06-12-2022, 06:37 PM | #5 |
Long hauler
Yeah I’ve seen other guys weld them open on trucks but most of Camaro owners would cut them out instead. I had mine cut out and never looked back as I already had AFM tuned out
06-22-2022, 08:29 AM | #6 | |
Got it fixed, I forgot what the exhaust was like before the rattling, what a difference!
