11-20-2016, 11:30 PM | #1 |
Drives: 2011 Camaro SS Join Date: May 2014
Door ABL RGB AMBIENT LIGHTING
I've see some posts about changing to a different color like red for instance. Does anyone or has anyone recently done a rgb swap for the doors? I'm hoping to get some guidance on what they used and how.
Sent from my iPhone using Tapatalk |
11-21-2016, 12:26 AM | #2 |
Drives: 2011 2SS/RS Callaway Join Date: Feb 2014
I changed mine, I had the stock lights but now have RGB on the doors and dash. I got mine from SJM autoprod. They have a great product
2011 Callaway SC572 2SS/RS, TVS 2300 Supercharger, 1-7/8" Kooks LT Headers, Fast 85# injectors, E85 Flex Fuel Conversion, Fore Twin Fuel Pumps, MGW flat stick short throw shifter, McLeod RXT twin disc clutch, Liberty Gears Tremec trans, DSS 1000 hp axles, Nitto NT555r drag radials, 10#'s of boost, 702 rwhp/ 697 torque, Recaro seat upgrade
11-21-2016, 10:54 AM | #3 |
11-21-2016, 10:54 AM | #4 |
+1
11-21-2016, 06:48 PM | #5 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
I use SJM as well, NightOwl is a great way to control them.
http://www.camaro5.com/forums/showth...=dash+door+abl |
11-22-2016, 01:30 AM | #6 |
Looking at the mod it looks difficult to just swap the light out with a rgb controller... if I'd only be doing the doors it would basically be taking the doors off, removing the old led, installing the new rgb unit and then finding a power source to tap into?
11-22-2016, 04:58 PM | #7 |
KNGTFALL
Swapping the light out is not difficult. It is getting a way to control the RGB LED within the door.
I'm not sure if other controllers that you can find online will work with the dimming feature of the doors/ or knob. The LP module from NightOwl use the PWM signal of the car to control all of the dimming. One way or another you need a controller to switch the colors of the RGB. |
