10-13-2022, 01:53 AM | #1 |
Drives: 2013 Camaro 2SS Join Date: Oct 2022
E85 N/A
I’m sure it’s been talked about I’m just not seeing much feedback , has anyone with a Ss4 nfc sbe 100% stock heads build gone E85 ? What gains did you get from the e85 ?
Is the Holley Hiram worth it ? What rpm are y’all shifting to ? (Auto) Is hollow valves definitely needed to rev to 7300 RPM ? Thanks! |
10-14-2022, 05:00 AM | #2 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Your going to gain about 5 hp switching to E-85. No matter the camshaft, unless you bump the compression significantly or add boost it’s not worth it on horsepower merits alone. It does smell great though. High ram is worth it. 7500, I have an auto car. The hollow valves put less stress on the whole valve train, if your trying to spin it past 7k I would say it’s a must.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
10-14-2022, 06:40 AM | #3 |
Evil Genius of Chevrolet
Just boost that shit
10-14-2022, 08:18 AM | #4 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
I made 721 on 93 and 801 on E60 10 minutes later (E98 poured into existing 93 in tank) at 13#. N/A you probably won’t see much.
10-14-2022, 09:46 AM | #5 |
Drives: 2010 SS L99 Join Date: Sep 2018
Hollow valves definitely needed? Not necessarily but recommended because its less strain on the valvetrain. I ran the solid L99 valves for 3 years with the SS4 spinning to 7600rpm, but when I had the heads ported last spring I went to hollow stems and spin to 7800rpm now. The high ram is good if you want to cut your hood, but the short runner intakes are really just starting to make power after 7000rpm and want boost or a solid roller setup. And like previously said, E85 won't yield much hp without a huge bump in compression or without boost. Good luck.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
10-14-2022, 02:33 PM | #6 |
Thanks for the feedback guys , what about springs ? Should I go from 660 springs to the 700 springs ? My plan is to throw a hi ram on the car , and rev to about 7300-7500 , right now it’s set to rev only to 6800-7000 I believe
10-14-2022, 07:58 PM | #7 |
Both work well. I had 660s for those first 3 years then went to to Pac 700s upon doing the heads and hollow stem valves, have had them in since March, no issues
10-14-2022, 10:30 PM | #8 |
Gotcha! What gains did you notice from porting the heads ? What times difference? I also want to port my heads and take advantage of the situation and swap the valves and springs
10-15-2022, 04:53 AM | #9 |
Gained 41rwhp from doing the heads and a 102 mm NW throttle body, the new springs went into it too. No new times yet.
10-16-2022, 02:24 PM | #10 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I find it curious no mention of cam by OP
10-16-2022, 06:23 PM | #11 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
OP stated it is a SS4 nfc cam. That is a GPI cam; stage 4 no fly cut.
More to come. |
10-17-2022, 02:54 PM | #12 |
Big Crow
