09-19-2019, 08:05 AM | #1 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Having trouble removing axle from differential
Has anyone had any difficulty removing an axle shaft from the rear diff? I watched a couple of Youtube videos that showed people popping them right out with a prybar. Mine is fighting me.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
09-20-2019, 02:14 AM | #2 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
FYI- Replied on the other post.
09-21-2019, 03:57 PM | #3 |
For future searchers:
I finally got it out. I ended up removing the diff from the car so that I could deal with it on the workbench instead of on my 47 year old back on the concrete. At that point, I could get a full swing on my BFH. I used the best thing I had on hand as a punch, that 1/2 inch drive extension. It fit through the divider between the side gears. After bashing the living hell out of it, I noticed that it had moved far enough to expose the seal surface. A few more heavy handed whacks and it came out. The circlip came out in 3 pieces. I expected it to be broked. You can see how it mashed the splines on the axle stub as it was squeezed between it and the side gear. The side gear is perfect, not distortion of the splines.
