05-01-2021, 10:54 AM | #29 | |
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
05-01-2021, 11:10 AM | #30 |
Did you check to see if the valve stem inside cores are tight? Sometimes if they aren’t then air can leak out there.
05-01-2021, 04:44 PM | #31 |
The valve cores were checked. My detailer took off one of the wheels (the worst one) and sprayed the entire thing down with soap. We could not find a single bubble. They swapped the air out for Nitrogen........so far so good. I guess I’ll find out tomorrow if they are still leaking. Is it possible that the rims are defective?
05-01-2021, 05:49 PM | #32 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
You really think you would get 4 defective rims? I highly doubt it.
Your car looks great. You’ll find the pressure issue shortly I’m sure. Then all will be good my friend👍 |
05-01-2021, 07:22 PM | #33 |
Thanks man! I guess the tires have a better chance of being defective. They are not that old so it's probably not them
05-01-2021, 07:56 PM | #34 |
Drives: 2018 ZLE Join Date: Feb 2018
Car looks amazing. I agree the ZLE looks very aggressive and angry.
05-01-2021, 08:33 PM | #35 |
Drives: 2017 2SS Join Date: Aug 2017
05-01-2021, 09:31 PM | #36 | |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
I hit a pothole HARD a couple days after getting my MP4S installed and immediately started slowly losing air...went straight to my local discount tire(they’re awesome) and they had a gigantic bowl of water they press it down into to check for bubbles. Turns out i busted a seam in the tire, not bent the wheel..they are pretty tough |
05-02-2021, 02:13 PM | #37 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Surprising
I’ve read 2 years ago somewhere on this forum that the 19’’ Rims don’t fit the MRC unless you cut some metal at the upper part of the MRC to make some clearance... |
05-02-2021, 02:31 PM | #38 |
Drives: 2021 Chevrolet Camaro ZL1 Join Date: Apr 2021
Tires will leak sometimes if there is dirt or contamination around the rim bead seal. I have had this happen and unmounting the tires, cleaning the rims and remounting fixed it.
food for thought
2021 Camaro ZL1
ADM S/C Expansion Tank Dual Aeroforce gauges Eibach Pro Lowering Kit Oracle Side markers (Paint matched) Rear window "wind screen" Xpel Paint Protection Ceramic Pro Coating |
05-02-2021, 06:56 PM | #39 | |||
I never thought about that. My detailer pumped up the tires with 32 psi of nitrogen yesterday. Today, the tires were reading between 30psi and 31psi. |
