08-10-2023, 08:28 AM | #1 |
oil in the intake tube
Does anyone else get oil in their intake tube from the fresh air inlet form the passenger side valve cover to the intake tube on a cold air inductions CAI? If so how did you stop it?
I've tried to get it to stop by putting on this oil filter from earl's but it still gets in there somehow.
08-10-2023, 09:06 AM | #2 |
Catch Can
08-10-2023, 09:29 AM | #3 |
I have a mishimoto catch can
08-10-2023, 09:37 AM | #4 |
08-10-2023, 09:55 AM | #5 |
Maybe something like the Mighty Mouse Wild setup that does a different routing
https://docs.google.com/document/d/1...JTcepoubI/edit |
08-10-2023, 10:04 AM | #6 |
Yeah that's what I was thinking about but hate to spend another $300 + dollars on a new set up. That's the only thing I can think of that would filter the clean side of the pcv system.
08-10-2023, 10:05 AM | #7 | |
08-10-2023, 10:52 AM | #8 |
I get that as well from my K&N system. Not all the time though. I know it is coming from that valve cover because if I disconnect the line from my CAI and just leave it laying along my valve cover/manifold it doesn't get in there, plus nothing comes out of the tube end to get on my valve covers. I don't know either. And I do have an RX catch can that does its job.
08-10-2023, 12:05 PM | #9 |
Anthony S
I had a mishimoto catch can, and a cold air inductions cold air intake. It was bone dry when I pulled the intake tube off. And I had it routed to my stock valve covers and then to my holley valve covers when I switched to those.
08-10-2023, 04:56 PM | #10 |
But I have extra big piston ring gaps for my boost later on. 25/27
08-11-2023, 06:28 AM | #11 | |
Anthony S
Also I just noticed that your catch can is not routed as intended. The mishimoto is supposed to have the inlet from the manifold and the outlet to the valley cover. It looks like yours in Tee'd into the valve cover port. Not sure if that makes a difference, I'm just pointing it out.
08-11-2023, 07:28 AM | #12 |
Yeah I've been talking to a guy at mighty mouse and I told him that I want to do it all (drag race, road race, and more) and he recommended thier mild can with the recirculating top. And then I told him my problem with the oil in the intake tube. So he said there's a modification that can be done to the can that will allow more to flow through the can to reduce the positive crank pressure but told me that the modification would have to be done by me giving no instructions on how to even do it. So that was the end of that conversation.
08-11-2023, 07:37 AM | #13 | |
08-11-2023, 08:13 AM | #14 |
GPI Sales Consultant
Your catch can setup only flows under vacuum - which you don't have at wide open throttle. That line is for venting crank case pressure, which with big ring gaps I'm sure you get a bunch of.
There are a few solutions, but I would get an Elite Engineering clean side separator. You'll cap the valve cover, and move the line to the clean side separator, which replaces the oil fill cap with a small air oil separator with a check valve so that it only flows when you've got pressure. The oil drains right back into the valve cover, rather than venting to your intake. Eventually, if you're adding boost, you'll need to rework your crankcase vent system in a more comprehensive way to handle the additional flow you'll see, and a vented can would make sense.
Got a question about a GPI product? Feel free to shoot me a message! |
