10-19-2022, 08:29 PM | #1 |
Overheating
So guy's my cousin has a 2010 SS ls3 manual camaro and he has a overheating problem. He has replaced the water pump and t-stat and the fans are working. He is at a loss. Any ideas? Thanks
10-19-2022, 08:43 PM | #2 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Clogged radiator?
"Make yourself sheep and the wolves will eat you"
10-19-2022, 08:46 PM | #3 |
Drives: Never just fly under the radar Join Date: Jul 2015
May seem silly but fans are running the correct direction?
Old Skool |
10-19-2022, 09:41 PM | #4 |
He hasn't changed any wiring on the fans.
10-19-2022, 11:03 PM | #5 |
Air in the system?
ABM #2399 2SS/RS:SOLD
10-20-2022, 04:04 AM | #6 |
10-20-2022, 04:32 AM | #7 |
It don’t come easy.
If the overheating started AFTER the water pump and t-stat were replaced, it definitely could be air in the system, especially if it was not properly purged.
10-20-2022, 04:43 AM | #8 |
I think that he told me it was overheating before he changed anything. That's why he started changing things. I was wondering if he actually got a bad t-stat? Or maybe he put it in backwards?
10-20-2022, 07:21 AM | #9 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Impossible to put the stat in backwards. I think if it were me, I'd verify the gauge is accurate before I did anything else.
10-20-2022, 11:35 AM | #10 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Any mods done? Check oil level, head gasket leak detector (it's a 2010 LS3 so there is a rad cap). Could have got combustion gases in the cooling system, which would cause overheating. The LS3 does not like to self purge if any air is trapped. Got to keep adding coolant at the radiator while squeezing upper and lower hoses while warming up. Watch for the fans and belts. Both hoses should be hot, along heater core hoses. Water pump pulley actually turning? Partially plugged catalytic converters. Enough fuel into cylinders for cooling (should throw a cel though if not).
10-21-2022, 06:40 AM | #11 |
Drives: 2010 SS M6 ABM Join Date: Mar 2015
Is it overheating or is he just getting the overheating error? I started getting that message on my DIC due to faulty Engine Coolant Temperature Sender.
10-21-2022, 07:17 AM | #12 | |
10-21-2022, 07:18 AM | #13 |
Yeah it's actually overheating, pucking up coolant.
10-21-2022, 08:04 AM | #14 |
