02-27-2021, 06:10 PM | #1 |
l99 low oil pressure
I didn't want to hi jack the "lowish oil pressure" post. So I've noticed my oil pressure sitting at 15psi at idle in gear when hot. Isn't the rule for every 1000 rpm your supposed to have 10psi of oil pressure? Or are my bearings just shot?
03-01-2021, 09:06 AM | #2 |
Well I figured out why my oil pressure is low. I was reading all the post on low oil pressure and found out that when I replaced the oil pump in my engine I put the wrong oil pump in. Like I said I was reading the post and seen the part numbers that everyone was posting and realized that I had put in the melling part number M365 which is a standard volume oil pump and I should have put the melling high pressure 10295 in because Ihave the l99.
My only question is when I do the l99 afm delete, will the pressure go back up or should I pull the pump and replace it with the right one?
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 Last edited by morepowerjoe; 03-01-2021 at 09:38 AM. |
03-01-2021, 09:19 AM | #3 |
Evil Genius of Chevrolet
Not sure on that . I think my builder put the 10295 in mine. I did the afm delete but kept my VVT.
03-01-2021, 09:33 AM | #4 |
I'm going to keep the vvt also. I just don't know if that will use more oil or just the afm lifters use more oil.
03-01-2021, 02:16 PM | #5 |
you're pressure isn't going to go up. If you aren't running the AFM you may not need the higher volume and will likely be fine.
03-04-2021, 01:58 AM | #6 |
I currently use mobile one 5w30 oil and filter. Do you think that I should go to a heavier weight oil like 40 weight?
03-04-2021, 03:01 AM | #7 |
No. That's treating the symptom, not the cause. These engines are designed for 5w30 due to their tighter tolerances/clearances.
03-04-2021, 03:10 AM | #8 |
I'm just consurned of the 15 psi at hot idle. But I was reading on all data and it says minimum oil pressure is 24 psig at 1000 rpm which I don't know what the g stands for but I have a little bit over 25 or so psi at 1000 rpm. My car idles at 500 rpm so do you think that is acceptable?
03-04-2021, 06:31 AM | #9 |
Drives: 2014 2SS/RS Join Date: Jan 2014
The "g" stands for gauge.
At sea level, the weight of the air above you is 14.7 pounds... That is called absolute pressure. So, if your gauge is reading 15 psig, that equals 19.7 psia. Or, if you have a gauge laying on your workbench, it reads zero (gauge), but you and it have 14.7 psia on you. The higher elevation you are at, the lower the absolute pressure, since there's less air above you. Gauge pressure is all that really matters, unless you work in a vacuum :-)
03-04-2021, 07:56 AM | #10 |
Thanks for the clarification, but what I really need to know is whether or not my oil pressure at 15 psi at a hot idle, in gear, at 500 rpm is ok?
03-04-2021, 08:04 AM | #11 |
There are ways to get a more accurate reading from the OBD port.
03-04-2021, 08:10 AM | #12 |
^^^This^^^ The gauges are good for general info and thats about it. Would be best to get a reading from the OBD port to see what the oil pressure really is.
03-04-2021, 08:22 AM | #13 |
I didn't even think of that, thanks. But if it reads 15 psi should I be worried?
03-04-2021, 08:34 AM | #14 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
I installed to 10295 and my oil pressure dropped to 20psi at idle in gear , when I spoke with melling they told me the right oil pump
Was the 10355 I tried that one and my oil pressure was back up to 25psi hot idle . Of course when I installed the Johnson 2110 I lost 3 psi of oil pressure at hit idle . As the Johnson lifters a slightly narrower than the stock ls7 lifters . |
