10-17-2021, 02:48 PM | #1 |
Junkie
Rear diff leaking
I have a 17’ 1LE 5k miles. Noticed the rear diff was glossy looking- had a coating of fluid. Upon further examination I saw the passenger side of the diff casing was also coated with fluid and there is a ring of fluid where the axle joins. Guessing maybe a bad seal. It should still be within the 5 year power train- not sure how involved of a repair this may be.
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
10-17-2021, 05:28 PM | #2 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
10-17-2021, 05:44 PM | #3 |
Junkie
What would be causing the fluid to cover the exterior casing? It looks like it dripped down- maybe a slow leak?
10-17-2021, 06:42 PM | #4 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Chevrolet TSB #16-NA-399 2017 Chevrolet Camaro https://static.nhtsa.gov/odi/tsbs/20...11767-9999.pdf
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
10-17-2021, 07:10 PM | #5 | |
Junkie
Thanks for the info. I think I saw this before but for some reason I thought I had the longer bolts.
10-17-2021, 07:21 PM | #6 | |
Junkie
10-17-2021, 07:32 PM | #7 | |
Are you the original owner?
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
10-17-2021, 07:48 PM | #8 | |
Junkie
Yeah I am the original owner. I don’t think the bolts were ever changed afterwards. Maybe they corrected them from the factory- explaining two marks?
10-17-2021, 08:04 PM | #9 | |
An older thread discussing these bolts. Nothing in here discussing torquing and backing them off. Now I’m curious if the first mark was the 37.5 lbs and the 2nd was the additional 45°?? I check those bolts every time the car is on the lift and I don’t recall seeing two torque stripes. https://www.camaro6.com/forums/showthread.php?t=505246
10-17-2021, 08:13 PM | #10 |
okay if you say so, here is a pic of a correct blue paint torque mark.
10-17-2021, 08:16 PM | #11 |
Junkie
Right but look at mine- I have two marks
10-21-2021, 11:09 PM | #12 |
Drives: Blue ss 1le 18 Join Date: Apr 2018
I have the same sipping condition on my diff housing, torque paint looks ok. Curious to know what the dealer says, keep me posted !
10-22-2021, 09:09 AM | #13 |
Def need to investigate that TSP, your bolts have backed out. Does that have anything to do with a minor leak, I don't think so and actually in standard olden timey time rear diffs it was extremely common to have some oily staining or residue on the cover.
10-22-2021, 04:02 PM | #14 |
I’m with you on the two marks. I don’t see how a bolt backs out and ends up with a 2nd paint mark lining up perfectly with the backed out bolt.
Have you had the time to check the torque on those bolts?
