Old 01-10-2019, 06:50 AM   #1
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
Camaro ZL1 Electronic Limited Slip Differential Drag Calibration
Looks like GM just released a new Drag Race calibration for the ZL1s. If it's anything like the Vettes with their new mag ride calibration, we should see a significant difference.
Calibration Details:
Continuous drag strip development combined with the pursuit of perfection have pushed our Camaro
engineers to develop an eLSD calibration that will enable more consistent burnout performance and
improved drag strip launches. The eLSD calibration will increase differential coupling strength during
burnout and drag launch scenarios. This is done by increasing the pressure applied to the clutch pack in
order to prevent relative slip between the clutch plates. End result will ensure burnouts warm both tires
evenly and launches to be straight and consistent.
Note: This calibration is for drag racing purposes only. The eLSD Drag Performance Calibration will only
be enabled
7WSM is offline   Reply With Quote
Old 01-10-2019, 06:53 AM   #2
Markoz28
Drives: 18 ZL1 nightfall grey A10
Soooo, how do we get this?
Markoz28 is offline   Reply With Quote
Old 01-10-2019, 07:03 AM   #3
7WSM
7WSM's Avatar
Go to the dealership and tell them to reprogram it. The cost is fixed at 350.00. Document ID highlighted because advisors will not have a clue what the hell you are talking about.
Dealer Installation Details:
To reprogram the “Camaro ZL1 Electronic Limited Slip Differential (eLSD) Performance Calibration" please call Techline Customer Support Center (TCSC) at 1-xxx-xxx-xxxx for programming requirements and instructions. Please be ready to provide the 17-digit VIN prior to calling. Please see detailed steps below:
Step 1 – Obtain VIN of vehicle for reprogramming.
Step 2 – Call TCSC at 1-xxx-xxx-xxxx.
Step 3 – See Calibration Reference Table below for specific Model Year application.
Step 4 – Refer to installation instructions in SI Document ID 84612071, for specific product details.
Step 5 – The labor for download and the re-flash of the module
Step 6 – Collect MSRP $350.00 from customer which covers ALL COST, including Labor for the download and re-flash of the module
Model Year Transmission Calibration Part Number
2017 + 10 speed Automatic 84627580
2017 + 6 speed Manual 84627581
Old 01-10-2019, 07:51 AM   #4
Markoz28
So will this add a mode for drag racing that we can turn on and off?
Old 01-10-2019, 07:56 AM   #5
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
We should also be able to do this on a SS 1LE, correct?
lgarrison34 is offline   Reply With Quote
Old 01-10-2019, 07:58 AM   #6
7WSM
7WSM's Avatar
ZL1 only for right now it seems.
Old 01-10-2019, 08:09 AM   #7
Marty31
Marty31's Avatar
Drives: 2019 ZL1 A10
This is interesting.
Marty31 is offline   Reply With Quote
Old 01-10-2019, 08:26 AM   #8
7WSM
7WSM's Avatar
Sorry, my copy and paste was weak from this morning.
Note: This calibration is for drag racing purposes only. The eLSD Drag Performance Calibration will only be enabled when the vehicle is in Traction Control System Off and Electronic Stability Control Off state.
So it's not adding anything, just when certain conditions are met.
Old 01-10-2019, 08:59 AM   #9
Markoz28
^ oh I see, thank you
Old 01-10-2019, 09:40 AM   #10
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
So I wonder if it will be active in Sport Competitive mode? That’s my go to mode for the strip.
BMWM.D. is offline   Reply With Quote
Old 01-10-2019, 09:56 AM   #11
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Very interesting. We did not receive a brief on this so will have to ask my rep. I'll get it done on mine straightaway. Hopefully there's more calibrations coming - but it's all hush-hush from team Camaro.
Can'tHave2MuchHP is offline   Reply With Quote
Old 01-10-2019, 10:19 AM   #12
Blast2hell
Drives: 2020 ZLE Rally Green A10
If you already have a tune, I'm guessing having them do this would be a problem.
2020 Rally Green ZLE A10
(SOLD)2017 NGM ZL1 A10 Built 3/31
Sebring Best Lap Time 2:29 Video
Roebling Road Best Lap Time 1:25 Video
Blast2hell is offline   Reply With Quote
Old 01-10-2019, 10:19 AM   #13
Mark R
Drives: 2018 ZL-1
I'm not sure what the e-LSD actually does. Why are there different "slippage" amounts that one can program into it?
Thanks.
Mark R.
Albuquerque, NM
Mark R is offline   Reply With Quote
Old 01-10-2019, 10:23 AM   #14
7WSM
7WSM's Avatar
It's programmed into the Chassis Control Module. As far as I know most aftermarket tunes only mess with the ECM and TCM
