01-11-2013, 10:12 PM | #1 |
Drives: 2012 SLP ZL770 #17 (Hugger Orange) Join Date: Aug 2011
ZL1 Belly Pan and LT Headers
Take a look at the pic below. The distance between the LT headers and the belly pan is about an inch. Wouldn't that be too close for comfort with the heat LTs produce? I imagine the belly pan plastic melting. What is everyone's thoughts here? Keep the belly pan off and sell since its new or keep it installed?
Thanks! |
01-11-2013, 10:15 PM | #2 |
Dont H8 Me Cuz U Aint Me
Drives: 2016 SS Sedan, 2017 Explorer Sport Join Date: Feb 2010
Yes you have to notch it out
01-11-2013, 10:18 PM | #3 |
Sorry, can you explain what you mean?
01-12-2013, 12:08 AM | #4 |
He means where your primaries are for the headers a section needs to come out. I attached a pic from MValdez17 so you can get an idea, that way you dont have to worry about it possible melting, though yours do seem to have a little more room, but I think its a safer bet.
01-12-2013, 12:20 AM | #5 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
I would run it like it is. You can check it in a few weeks to see if there's any melting. Worst that can happen is that it melts where it's too close. If it does, you then know how far you have to trim.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
01-12-2013, 01:41 AM | #6 |
Drives: 2010 Camaro 2SS/RS Join Date: Oct 2009
There should be some insulation/shielding to help with the heat. The only reason I cut mine was because they long tube sat lower than the belly pan. I would leave it and keep an eye on it. Its not thin plastic so it will handle the heat a little better.
If you feel that it will cause problems, then cut around the headers, like I did on mine.
01-12-2013, 02:05 AM | #7 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
OP, which headers are you running?
01-12-2013, 06:44 AM | #8 |
Thanks for the advice so far! I'm running SLP LTs with magnaflow HighFlows.
01-12-2013, 03:57 PM | #9 |
Supercharged LSX
Most I've seen hang below the sub frame. Do you know it they are 1 3/4" or 1 7/8" primaries?
01-12-2013, 06:08 PM | #10 |
1 3/4. What are your thoughts?
01-12-2013, 07:33 PM | #11 |
Drives: pleather and Chiclets Join Date: Mar 2012
I would leave it. Worst case scenario it melts or bubbles the pan and you can take snips to it to notch it. My zl1 belly pan has heat shields in that area so that may be good.
01-12-2013, 07:36 PM | #12 |
I can take pics of the heat guard thingies if you want, my pan is sitting in garage.
01-12-2013, 07:42 PM | #13 |
Drives: 10' 2SS LS3 M6 Join Date: May 2012
part # on the belly pan?
01-12-2013, 08:16 PM | #14 |
Were the heat shields from GM or you got them and added them? Do you have LT headers?
