Old 05-29-2020, 09:33 AM   #1
qealston
Drives: 2015 Chevy Camaro LS
Wheel offset for 22inch rims
Hello I’m interested in purchasing Forgiato Flow 001 rims 22” but I’m kinda puzzled on the offset. The only offset listed for my hub size is +15 & +25 for the front & +43 +38 & +18 for the back. I’m gonna run 22x9 on the front & 22x10.5 in the back. Can someone please help me. Pictures would be a plus
qealston is offline   Reply With Quote
Old 05-29-2020, 10:59 AM   #2
DRKS1D3
DRKS1D3's Avatar
Drives: '17 Corvette Grand Sport M7
The more "positive" the number, the more flush the spokes will be with the fender (more back spacing). The more "negative" the number and the spokes will sit farther back in towards the rotor (less back spacing).
Decide on if you want a flat looking wheel or a deep-set looking wheel.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ
DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 05-29-2020, 12:31 PM   #3
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
It is confusing at first but you will get it. See if this helps.
What is Wheel Offset?
Wheel offset is the distance in millimeters from the center line of the wheel to the mounting surface. If the mounting surface is closer to the face of the wheel it is known to have a positive offset and if the mounting point is closer to the inside of the wheel it has a negative offset. Center or no offset is when the mounting point is directly on the centerline of the wheel.
What is Wheel Backspacing?
Wheel backspacing is the distance in inches from the mounting surface to the inside edge of the wheel. A wheel's width is from the mounting points of the tire beads, therefore the measured width of a wheel from outside edge to outside edge is about an inch wider than spec. An 8" wheel will measure 9" from side to side, this makes converting offset to backspacing not so straight forward. If an 8" wheel has a center offset the backspacing is not 4", it is actually 4.5".
acutron42 is offline   Reply With Quote
Old 06-09-2020, 04:05 PM   #4
Leonardbb
Drives: White ss
Did you ever choose your new wheels? I have the same question
Leonardbb is offline   Reply With Quote
Old 06-09-2020, 04:27 PM   #5
acutron42
acutron42's Avatar
Here is a calculator to help you out.
https://tiresize.com/wheel-offset-calculator/
Old 06-09-2020, 05:24 PM   #6
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
Front 22x9.5 -23 offset rear 22x10.5 -38 offset
kinda a walk around vid with mrr 228’s 22” rims...note my car looks dif now
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 06-10-2020, 06:06 AM   #7
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
My Setup - no rubbing, no issues other than a little stiffer ride. Car has C/O's and lowered somewhat, esp cause the new tires are ~1/2" smaller diameter. Proper Stance and a good alignment (esp if lowered) is important.
Foose 22" Wheels and Pirelli Tires
FRONT: 265/30-22 = 28.3" tall, with 9.0" wide wheel with 35mm offset
REAR: 315/25-22 = 28.2" tall, with (10.5" wide wheel is what I have) or 11.0" with 45mm offset
Front: 28.7" dia stock 245/45-20 tire – 28.3" new tire = 0.4 smaller diameter.
Rear: 28.7 dia stock 275/40-20 tire – 28.2 new tire = 0.5 smaller diameter.
hesster is online now   Reply With Quote
forgiato, forgiato wheels, offset, rims
