AWE Tuning
Old 08-25-2021, 06:14 PM   #1
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
1LE Wheels On 2SS Camaro?
Pretty sure that 1LE wheels will fit on a 2SS Camaro. But could someone please confirm this?
And will there be any recalibration of speedometer needed?
Contemplating getting a set of 1LE wheels and just want to make sure they will fit be for I plop down a significant chunk of change.
Thanks.
Spaceme1117 is offline   Reply With Quote
Old 08-25-2021, 06:15 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yes they will fit no problem
Old 08-25-2021, 06:40 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Here you go.
Old 08-25-2021, 06:41 PM   #4
Freebird
Freebird's Avatar
Drives: 2014 2SS/RS 1LE Camaro&16 Silverado
Yes, but 1LE wheels are offset so keep in mind you will not be able to rotate them.
I have a 1LE.
Sent from my SM-N950U using Tapatalk
Z28 Brake ducts, CAI & Tune
"Never let fear decide your fate!"
Freebird is offline   Reply With Quote
Old 08-25-2021, 09:05 PM   #5
Vaska
Drives: On Hiatus
I have a 1LE.
What.
450hp RWD V8 and you are worried about tire rotation?
Vaska is offline   Reply With Quote
Old 08-25-2021, 09:37 PM   #6
lubeman1969
Drives: 2018 2ss m6
I’m trying my best to find a set of Oem 1le wheels in really good shape and not having much luck. Already bought some new SC3’s and ready for wheels. The MRRs are nice, but really want oem
lubeman1969 is offline   Reply With Quote
Old 08-25-2021, 10:03 PM   #7
atx_traveler
Drives: blue velvet
I have a 1LE.
Stock SS wheels are different sizes Front and Rear as well.
atx_traveler is online now   Reply With Quote
Old 08-26-2021, 05:38 AM   #8
Spaceme1117
Yeah, my 2SS has different front and rear sizes. Not a problem.
My main concern is throwing off the speedometer reading and or the electronic nannies.
Old 08-26-2021, 10:01 AM   #9
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
TL;DR: you'll be just fine.
Nannies will be happy (front to rear ratio will only change by -2.2%), speedo will be slightly off as this combo is shorter, see below. You can go up to 315 wide in the rear to offset that a little if you want, but probably not worth it.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 09-10-2021, 07:56 AM   #10
Spaceme1117
So purchased a used set of OEM 1LE wheels from the classified's section. Not perfect as the wheels have some curb rash but my car is not perfect either. Came with a set of Michelin Pilot Sport 4S tires with 60 to 70% tread remaining.
Put the wheels on last night. These wheels are awesome and really make the car look even more badass.
Car seems have a more comfortable ride also. Not sure if its the lower pressure (32 psi vs 35 psi) or that I am going from RunFlats to non-RunFlats but it is nicer.
Old 09-10-2021, 09:21 AM   #11
Justcruising
Justcruising's Avatar
Drives: 2019 Chevrolet Camaro 2SS
Looks pretty damn good to me Sir
Justcruising is offline   Reply With Quote
Old 09-10-2021, 01:26 PM   #12
Joshinator99
Agreed! Love it!
Old 09-10-2021, 01:55 PM   #13
arpad_m
arpad_m's Avatar
Badassery to the gills You bet the ride is better on non-runflats, even despite having less sidewall.
You might want to do one more thing, now that you have a front splitter, remove those eyesore ugly rubber air diverters from underneath the front bumper.
735 rwhp | 665 rwtq
Old 12-27-2023, 06:39 PM   #14
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
I know this is an old thread, but I have a question. Thinking of getting a set of MRR replicas, but it appears that the new 1LE setup created a slightly larger gap between the top of the tire and the top of the wheel well, as opposed to the stock SS setup?
SSShark is offline   Reply With Quote
