06-05-2021, 01:59 PM | #1 |
Ruthenium Sparkplugs - Opinions?
I have seen that NGK makes ruthenium tipped spark plugs now. Supposedly even better than iridium tipped plugs.
Supposed to give better cold starting and throttle response. The part for the LT1 has a double fine electrode which to me looks like they may actually help as it may expose more of the air/fuel mixture to the spark. Any one try these out or have any experience with them? |
06-05-2021, 03:50 PM | #2 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Stick to Iridium.
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
06-05-2021, 11:45 PM | #3 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
From what I have seen, people just say the car runs smoother, which could be a placebo.
I wouldn't expect anything quantifiable when it comes to power gain.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
06-05-2021, 11:50 PM | #4 |
Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
I definitely wouldn’t go through the a** pounding of changing spark plugs just to find out...
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
06-06-2021, 10:22 AM | #5 |
Hot Camaro
Stick with stock. GM chose a plug that fit with their engine needs and it will perform well.
I've been down the avenue of swapping to different types and such, and it just doesn't have ANY positive aspect on newer cars (unless you have a specific need to switch the plug due to bolt-on's or a tune). In fact, I've found that overall plug life got worse when changing to "better" plugs and the engines never ran any better. |
06-06-2021, 07:08 PM | #6 | |
Ever see anyone change spark plugs on a rotary before? Now that's some effort. Or better yet, Subaru's...
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) Last edited by UnknownJinX; 06-06-2021 at 07:20 PM. |
06-06-2021, 07:48 PM | #7 |
Found a somewhat helpful reading for real world usage of these plugs.
https://m.facebook.com/adamtuned/pos...?locale2=pt_BR
Current:
06-07-2021, 02:02 PM | #8 |
I was not a fan. But maybe because I did my after I did my headers and relocated the wiring harness over the passenger front plugs. Removed the coolant tank for better access. Also lost an old plug to the Camaro gods somewhere deep in the motor mount.
492WHP 473WTQ |
06-07-2021, 02:23 PM | #9 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Ruthenium sounds like some type of material from Runescape
06-07-2021, 02:29 PM | #10 | |
Hot Camaro
Since a colder plug removes heat more quickly and reduces pre-det / knock, it would seem that colder Iridium would garner identical results and at a lower cost than the Ruthenium. |
06-07-2021, 03:06 PM | #11 | ||
Also, wouldn't run colder plugs on a stock or mildly modded car if you are daily driving it. It could foul the spark plugs. It seems like most people online who notice a difference are either due for a spark plug change anyway(so even new Iridium spark plugs could also have made the same improvements), or are turbocharged(which are harsher on the spark plugs to start with). So with a stock NA car, I doubt there is much benefit as Iridium spark plugs are already good for 100k miles or so, and there are concerns with spark plugs fusing with the aluminum heads if the spark plugs are left in for too long. With the FI cars, there could be some benefit from the Ruthenium plugs as they don't tend to last as long(I think the FI Camaro's need spark plugs at 60k miles instead of 100k miles). Even on the NGK website, the performance difference between Iridium and Ruthenium is very small. They quote a 0.2 second advantage with Ruthenium over Iridium over a period of 23 seconds, so with our cars that can do 0-60 in mid to low 4 seconds, the ambient temperature can probably cause more fluctuation than Ruthenium spark plugs ever could. So... Yeah, I wouldn't try them unless I am due for a spark plug change anyway.
Current:
06-07-2021, 03:09 PM | #12 | |
Hot Camaro
06-08-2021, 10:43 AM | #13 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
I imagine these would be the same at the beginning of their life as iridium, then as you reach 75k miles and beyond, the difference gap widens a bit with these outperforming the iridium. With these plugs basically being one-and-done for the life of the car.
I'd expect these to become standard in many vehicles assuming ngk can make enough of them as they turn them into something you'd only need to service if the car was failing in some other way (bad injector causing plug fouling or overheating or bad gas) |
06-08-2021, 11:22 AM | #14 |
Maybe. And will that result in any measurable performance difference?
The igniter on my weber grill has been sparking to what's left of the rusted plates for 20 years. The gas always seems to find the spark. |
