02-11-2024, 04:24 AM | #141 | |
02-11-2024, 08:08 AM | #142 |
Drives: 22 ZL1 M6 Join Date: Oct 2018
do you guys not like the IGLA system or the "killswitch" I posted because they are intrusive?
I like the immobilizer fuse you guys have been posting as well but these two above are much more hidden IMO, IGLA is far far superior than ravelco and IF somehow IGLA fails, it fails open. Raveclo pins wear out = not great news
Sold: '17 m6 2SS [arctic blue]
Current: '22 m6 zl1 [vivid orange] |
02-11-2024, 08:47 AM | #143 | |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
02-11-2024, 10:19 AM | #144 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
02-11-2024, 10:36 AM | #145 | |
There is an installer here who has done a manual SS 1le so I think the firmware is out there. There is a bit of a delay when starting the car up now, and the IGLA fobs can be hit or miss. I believe there is a phone app too to bypass punching in the code each time. My friend uses the fob to bypass the code and so far so good, just have heard things with the fob. It is a toss up between IGLA and the push to start immobilizer.
02-11-2024, 10:37 AM | #146 | |
02-11-2024, 10:55 AM | #147 |
But these don’t cost much. And my car isn’t a daily, doesn’t go to malls and such and is garaged. If it was and was parked in not so good areas, then yes Igla would be good. Until they use a tow truck
02-11-2024, 11:05 AM | #148 |
very true
02-11-2024, 11:13 AM | #149 |
It’s really maddening that we do have a great alarm system with whole car immobilizer. That theives can defeat it with a scanner/relay method, or just the scanner and break a window and plug into the obd port and steel the car so fast. Pathetic we have to, if desired,to install another whole alarm system!
02-11-2024, 12:56 PM | #150 | |
Drives: 2024 Camaro 1SS M6 Join Date: Nov 2023
For me, it is not that I don't like the IGLA (I think Chevy should use a pin system for all keyless vehicles, but that's just me). However from checking the IGLA site and calling some local shops, there aren't many installers in my area, and I'm not exactly in the middle of nowhere, so it makes it less desirable to have to drive possibly several hundred miles to have the system installed. And if something goes wrong with it, how to get service. Also concerned about voiding the warranty. The Mobilistics option is straightforward and if it fails, I pop the old relay back in. Combined with some other measures/deterrents, I'm pretty happy with that. Like others said, if this was my daily driver I might think differently but I'm my case it is a garage queen/weekend toy. |
02-11-2024, 01:14 PM | #151 |
I haven’t checked all the posts, but check your door lock options in settings. Mine was set so you can lock/unlock with the door handle as well as fob from the dealer. I turned off the unlock with door handle option . Even with fob next to door you cannot open the door with the door button. I simulated a broken window by rolling it down ( not sure that replicates it or not) to try to unlock door with the buttons inside the car on the door. Can’t do it. Trunk obviously locked to. If a relay attack is done I have no idea if they can re enable the manual option. And with fob next to door it still won’t open so relay attack would appear not to work. Just keep fob in a faraday pouch. Some thoughts for you all .
02-11-2024, 01:58 PM | #152 | |
02-11-2024, 02:04 PM | #153 | |
2020 Camaro 2SS - Riverside Blue, NPP, Magnetic Ride, Sunroof
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
02-11-2024, 02:08 PM | #154 | |
https://www.mobilistics.com/tx-21-no...d-transmitter/
