BeckyD @ James Martin Chevy
Old 01-25-2018, 01:53 PM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
The orange spring spacers
So when I bought my 1LE last year I informed the salesperson that the orange spacers were not with the car. No problem he said. I'll get you some. Turns out the set he gave me are grey. Anyone know what car these are from, or if they are OK? Thanks.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 01-26-2018, 05:52 AM   #2
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Ok?
Ok for what?
The orange spacers were for train/truck transport from the factory to the dealership, then they were to be removed and thrown out.
There is no real reason to use them ever again, unless you are having your car mass shipped across the country by people who view your car as cargo at $0.20/lb.
It's like wanting to save the styrofoam from the TV you just bought.
I guess I just don't understand, sorry.
Old 01-26-2018, 07:07 AM   #3
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I didnt think the 1LE came with these, only the ZL1.
Old 01-26-2018, 07:12 AM   #4
4mulafastech
4mulafastech's Avatar
Drives: 2018 1SS 1LE
My SS 1LE came with orange spacers and I kept them. If I need to load the 1LE on a trailer some day it can be good to have them. They raise the front end to help prevent damaging the chin spoiler when loading onto the trailer.
OP - Do you have a picture or measurements? Maybe they are just a different color but the same size.
4mulafastech is offline   Reply With Quote
Old 01-26-2018, 07:16 AM   #5
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
My dealer grabbed some for me off a ZL1 but they are yellow.
mjk3888 is offline   Reply With Quote
Old 01-26-2018, 09:16 AM   #6
Dmaxcc6spd
Dmaxcc6spd's Avatar
Drives: 71 Camaro SS - 17 Camaro SS1LE
How much altitude do these spacers yield when installed? I just bought Race Ramps so I could load my 1LE on my trailer. It's an H&H tilt-bed 12K rated and a fairly steep angle to load. Without the Race Ramps there was no way I could get the car on the trailer. Even with the ramps, there isn't much clearance. Some additional height would yield a more comfortable loading experience.
79 Camaro RS (my first Camaro)
71 Camaro SS
94 Camaro Z-28 (sold when gas hit $4/gal)
14 Camaro RS (gone - totaled by 8&9 year olds)
17 Camaro 1LE HBM Ordered 02/21 Built 4/24, Delivered 5/4
Dmaxcc6spd is offline   Reply With Quote
Old 01-26-2018, 09:21 AM   #7
rootus
Drives: 2018 HBM SS 1LE
Originally Posted by Boost Creep View Post
Ok?
Ok for what?
They are to add clearance when you put the car on a truck, whether from the factory to you, or you to somewhere else. The PDI actually states explicitly they should be given to the customer, not thrown away.
rootus is offline   Reply With Quote
Old 01-26-2018, 09:33 AM   #8
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Serious question......how exactly are they installed? Do they require removing the wheel?would you have to use some serious force to separate a couple coils? I only ask because this is something that would need to be done road-side....before a tow.
They are discussed a lot, shoot, even I had my dealer order me a set after they likely trashed mine during PDI. But it’s never mentioned HOW they are to be used.
ninetres is offline   Reply With Quote
Old 01-26-2018, 09:39 AM   #9
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Ok?
Ok for what?
This is correct. Unless you’re putting your car back on a transport/flat bed for long distance. It enables the trucker to ratchet down the suspension to a solid-state and not get any spring movement at all. Other than that, they are worthless.
Old 01-26-2018, 10:11 AM   #10
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Glen, I thought they were needed if you had to tow your car on a flatbed, because of the approach angle.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 01-26-2018, 10:12 AM   #11
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
They do mine are in the glove box
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 01-26-2018, 10:20 AM   #12
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Ryan B.
Thanks!
Old 01-26-2018, 12:07 PM   #13
Boost Creep
Drives: '18 1SS 1LE
I'm pretty sure you have to jack up the front of the car to unload the front springs some, then you could work the spacers into place. I don't think this is something you are just going to poke into the spring and raise the front end.
Old 01-26-2018, 12:08 PM   #14
Boost Creep
Drives: '18 1SS 1LE
Did not know that, as previous times these were installed on cars they were to be discarded.
