Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
BeckyD @ James Martin Chevy
Old 05-08-2019, 06:30 AM   #15
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
Pretty sure I just tapped the wires on the 12V socket.
TonyNo is offline   Reply With Quote
Old 05-08-2019, 12:59 PM   #16
Camaro_49
Drives: Camaro
Yes but how did you do that with just the shifter trim removed? I can’t even see the wires with the trim removed, the cigarette socket is a few inches away and there’s no way that I can see to get to it with the small opening that is allowed. Do you remember how you were able to reach that far away to get the cigarette lighter lines?
Camaro_49 is offline   Reply With Quote
Old 05-08-2019, 04:03 PM   #17
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
This might be kinda late but im doing something similar to power my dash cam. Im running a hardwire kit that goes from the mini USB to the fuse box so I can plug my dash cam in without taking up an outlet.
They have these hardwire kits that also just come out to 1 or 2 female USB ports so you could just mount that anywhere you wanted.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
Black on black 2019 3LT RS Camaro.
1100: 3/7/19 | 4200: 4/15/19
3100: 3/15/19 | 4800: 4/23/19
3400: 3/22/19 | 5000: 4/25/19
Built: 4/8/19 | Home: 4/26/19
RideWithDanger is offline   Reply With Quote
Old 05-08-2019, 06:07 PM   #18
TonyNo
TonyNo's Avatar
If it's that far away and hard to get to, I got power from somewhere else (likely one of the harnesses that's in there). Likely the Shift Lever Position Indicator harness (has a 3-pin connector).
If I get a chance, I'll pop my shifter bezel off tonight and look. I'm surprised I didn't take any pics when I did that.
Old 05-08-2019, 06:08 PM   #19
TonyNo
TonyNo's Avatar
Take a look here, too.
https://www.camaro6.com/forums/showthread.php?t=537790
Old 05-11-2019, 04:37 PM   #20
TonyNo
TonyNo's Avatar
Okay, I forgot. I'll do it tonight.
