Old 03-18-2023, 06:59 PM   #1
L78toLT1
L78toLT1's Avatar
Drives: Hyper Blue 2016 2SS 6M
Is this a recipe for disaster?
Hey guys, I am registered for my first track say of the season at Road Atlanta tomorrow. In order to make it to the track in time for registration, tech check, driver's meet, etc. I will need to leave home at 5:30am, when the temperature is forecasted to be a balmy 25 degrees. It's a 65 mile ride to the track.
The car is basking in a 70 degree garage where it will remain until I head out for the track. I'm running Goodyear Supercar3's. I'm hoping that immediately getting on the road with warm tires will enable me to make it to the track without incident.
Assuming I make it to the track, the temp should be around 35 degrees for my first session. The forecast calls for full sun all day, which will certainly help. By my 2nd session, it will have warmed up to 40 degrees. What do you guys think? I have a good bit of tracking experience, but have never driven summer compound tires in temperatures any where near this cold. I was caught with my pants down in this situation. 25 degrees in Georgia this time of year is certainly not the norm.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned
L78toLT1 is offline   Reply With Quote
Old 03-18-2023, 07:24 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I drive my 5th Gen n colder without issue you just have to be smart about things.
Orange Krush II
Old 03-18-2023, 07:39 PM   #3
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
You will be fine, I've done several trackdays at this point where the temps start below freezing and go to around 40F by the hottest part of the day. Take 2 or so laps to get your tires up to temperature depending how aggressive you drive. The first 4-5 turns will have 0 grip.
Christian1LE is offline   Reply With Quote
Old 03-18-2023, 08:18 PM   #4
L78toLT1
L78toLT1's Avatar
Thanks man. I'm not to worried about it when/if I make it to the track. It's the 65 mile ride to the track in 25 degree temps is just plain scary.
Baby Blue
Old 03-18-2023, 08:24 PM   #5
L78toLT1
L78toLT1's Avatar
My scariest experience so far is when i drove in the mid 30's, in rain. I survived that, so 25 in the dry may actually be a piece of cake.
Baby Blue
Old 03-18-2023, 08:28 PM   #6
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Agree with the above replies. Your tires will be fine. The worst part would be when you leave home, but you're keeping them warm in the garage. Once you're rolling on them, they'll generate enough heat to avoid any damage. Once you start making laps at the track, they'll generate quite a bit of heat for themselves.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 03-18-2023, 10:12 PM   #7
Silveradoss573
Drives: Camaro 1LE
I went through this about 2 years ago and had no issues. Although not quite as cold, we left at 5am with temperature around 30*. I picked a route that kept the speed up to keep as much heat in the tires for the 1+ hour trip to the track. Also ran a space heater in the garage the night before to get as much heat in the tires as possible. My garage usually sits around 70* year-round to begin with. When we opened the door that morning to leave, it was around 78* so we had a good starting point. My car has the Goodyear Eagle Supercar G:2's btw so obviously not quite as soft as yours but still concerning as I never drive the car in those low temps. Still had to be very cautious and gentle with throttle but not as bad as I was expecting. 👍
Silveradoss573 is offline   Reply With Quote
Old 03-18-2023, 11:36 PM   #8
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
The 3Rs don't grip until warmed up on the track. Car will be loose. Be careful on warm up with maybe two laps in the first sessions. Driving there should be ok at 25F, air up for the drive.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 03-19-2023, 03:58 PM   #9
L78toLT1
L78toLT1's Avatar
Just finished my last session and the tires were a non issue both on track and on the way over. It was just so stupid cold this morning that I didn't know what to expect. While I will avoid track days that barely get out of the 30's in the future, at least I know that, if push comes to shove, I can make it work.
Baby Blue
Old 03-19-2023, 04:55 PM   #10
Christian1LE
The worst part about driving in the cold is that you're forced to keep the windows open, and even with gloves on my hands will freeze at those temperatures. I usually can only stay out there for 15 minutes or so before my hands turn into ice.
Old 03-19-2023, 09:57 PM   #11
cdrptrks
cdrptrks's Avatar
Drives: 2017 Blue Camaro 1SS 1LE with PDR
I would not try to drive on Supercar 3Rs in 25°F temperatures! I was spinning the rear tires at half throttle in 1st and 2nd gear with traction control on in the paddock when they were 40°F! Maybe it would be ok because of the heated garage but I wouldn't try it. Agreed about being careful warming them up...I started using PTM Dry for that when it is cold outside and even then they are sketchy for 3 laps. I have nearly lost control driving 3Rs with traction/stability control off when it is cold outside several different times (including on a straightaway) and I have seen others spin out on them when the tires are cold.
Thankfully the OP had Supercar 3 (not 3R). I drove on Supercar 3s in the high 20s °F to VIR after the car set outside in the cold all night at the hotel and thankfully had no issues but I was uneasy about doing it.
cdrptrks is online now   Reply With Quote
Old 03-19-2023, 10:05 PM   #12
cdrptrks
cdrptrks's Avatar
The car is capable of the fastest lap times in cold temperatures if the sun is out to warm up the track surface but it is definitely not the most comfortable experience for the driver!
Old 03-19-2023, 10:45 PM   #13
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Tell me about it! Last February I did my first (and only) cold day at VIR. Right around freezing overnight at the hotel. I drive to the track and the DIC is telling me the tires are cold the whole drive there. I think they didn't hit "normal" until I pulled into the VIR property. Of course by the time the first session started they were cold again.
On the track in the morning, traction was down, as the day was only partly sunny, and it was taking me about 2.5-3 laps to get the tires warm. Some suggested I slide the car around a bit to try to warm the tires faster, but that was an uncomfortable feeling because there wasn't much demarcation between traction and exceeding the limit. Whoever coined the phrase "like driving on hockey pucks" wasn't kidding!
So how do you guys go about warming the tires as quickly as possible on track?
N Camarolina is offline   Reply With Quote
Old 03-20-2023, 07:28 AM   #14
Msquared
Msquared's Avatar
Guys, unless I'm missing something, the OP is on SC3s, not 3Rs.
Matt Miller
2020 SS 1LE
