02-18-2023, 07:34 AM | #1 |
Crank position sensor relearn using HPTuners
Does anyone know if the crankshaft position sensor relearn procedure can be accomplished using HPtuners?
Baby Blue
02-18-2023, 07:57 AM | #2 |
Not sure, maybe King will chime in on that one.
02-18-2023, 08:03 AM | #3 |
Yeah, I was thinking of PMing King, but though I'd create a thread for the benefit of the rest of the community. My car is running fine, but I've got the crank relearn fault code.
Baby Blue
02-18-2023, 09:16 AM | #4 |
I have never had to perform a crank relearn. So, I am not sure if that feature in HPt works on this platform. I would give it a try and see if it works. If it doesn't you will need to find someone with a tech2 type device I believe.
2016 NFG 1SS A8
02-18-2023, 11:01 AM | #5 |
Jim, I have a "medium kahuna" D8 scan tool and will check today if it can do crank relearn for GM vehicles. As per the manual, it should be supported. If yes, I can drive over to your humble abode and do the needful if you want, just text me.
02-18-2023, 11:48 AM | #6 |
My experience is, I put the car in service mood, flash the ECM/TCM with HPT, exit service mood, it then relearns the crank position when you hit the start button once or twice, then it will start.
'20 ZL1 1LE A10,
02-18-2023, 05:18 PM | #7 | |
Thanks, Arpad. I may take you up on that!
Baby Blue
02-18-2023, 06:00 PM | #8 |
I'm currently remote tuning my car with Ted Jannetty, so my ecm has been reflashed several times and the stubborn crankshaft relearn DCT won't go away. I will run this issue by Ted on Monday when we resume tuning.
Baby Blue
