11-05-2020, 07:54 PM | #15 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Now I WILL BE buying a track set up but it will be square as well with APEX EC7 18 x 11 wheels ET25 and Hoosier A7 tires sized at 315 30 18. Now my set up is helped quite a bit by the fact that I run -3.6 degrees negative camber on the front using VORSHLAG camber plates (I adjust them back to -2.2 degrees camber before leaving track). The REARS are adjusted to -2.2 degrees camber which I use at track as well as street . The reason I am moving to 18's at the track is because you can readily get race scrub tires with 75% wear LEFT on them for about 100-125 dollars a tire in 18" sizes. Plus the car will handle better with 315's on the front and rear compared to my street/track setup of 305's. Lastly the 18's are lighter and they will also lower the car to the ground.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
11-05-2020, 08:00 PM | #16 |
Drives: 2017 ZL1 Join Date: Aug 2020
I bought a takeoff set of 19" gy3r's before thinking things through. Once I discovered the car would not fit in the existing enclosed trailer used for my sons C5 I sold the takeoffs and got some regular gy3's in 19" and bought some Apex arc 8's to put them on.
I now drive to the track (350 mile round trip) on the 19" setup and plan on using them for dd. They performed admirably at my first roadcourse with the car. Going to keep my 20" stockers with rear r888r for straightline events for now. Those definitely don't wear well and are more costly to replace. Shipping tires anymore has become economically unfeasable for me. $60/tire shipping makes take offs less attractive. |
11-06-2020, 04:03 AM | #17 | |
Drives: chevrolet camaro Join Date: Jun 2020
Do you have more photos in better resolution? I would love to see them. And I also want to tell you about college essay writing service. Have you tried it before? Last edited by jamessw; 04-22-2021 at 08:58 AM. |
11-06-2020, 11:31 AM | #18 |
Are you guys finding SC3's in 19" ZLE sizes for under $1k? It probably sounds like I'm a cheapskate but I'm really not. I'm just trying to figure out which wheels to buy. If the 3's and 3r's are both readily available in 19" ZLE sizes then it's a no Brainer. If the availability is not as good, I'm perfectly fine with picking up another set of oem 20" wheels
Baby Blue
11-06-2020, 11:49 AM | #19 | |
Yup i have tons of photos what are you looking for?
11-06-2020, 12:58 PM | #20 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
Probably an indication that the old stock G3s will be out soon. The G3s are more economical in 20" and the G3Rs are more economical in 19" because of the OEM sizes. Edit: G3Rs are never more economical, just meant cheaper in 19s I would like to see a direct comparison between OEM G3s and 305/30/19 G3s, but who really wants 2 sets of the same tires |
11-06-2020, 02:07 PM | #21 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
However, I think for most people around here it'd probably be a slight increase to lap times if just throwing them on. In my experience you need to tweak your setup a bit to be optimized for a square setup, plus if the driver is using PTM the 19" square wheels (on the SS 1LE at least) don't seem to play as nicely with that and the eLSD as stock sizes do.
2017 SS 1LE.
