12-28-2019, 10:20 AM | #1 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
Fast list
So I've been looking at and comparing my times vs mods against everyone else on our bolt-on fast list and my car seems waaaay off the mark. I'm not sure why or what could be the cause of it, but some of the times are insane. 11.3 @ 119 mph vs 12.3 @ 112 for me. That's a full second and 7 mph difference. That takes either a shit load of weight reduction or my engine is a big ass turd....... The only difference in mods listed is bigs and Littles but that's worth at most a tenth or 2. Cuts about 100lbs of weight from the car. Anyone else care to chime in?
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
12-28-2019, 10:33 AM | #2 |
Drives: 2010 SS L99 Join Date: Sep 2018
It does tend to strain credulity, when lots of the cammed all motor crowd are struggling just for 11.5 and you see 11.2-11.3 on a bolt-on without internal modifications list... then again the fast list IS on the honor system. For just bolt-ons, you're doing just fine, really.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
12-28-2019, 10:57 AM | #3 |
Are you considering gear changes and torque converter changes? Those make a big difference.
12-28-2019, 12:18 PM | #4 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
The Fast List broke my heart too.
Your numbers look fine to me. A lot of it has to do with average DA. During the summer, we never see many days below 4-5K ft. I often dial in at 12.3 and I have gears and a cam. You are running comparable ETs with just bolt ons.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
12-28-2019, 12:45 PM | #5 |
Yeah my mods are in my sig. I just don't see how anyone can run that fast with the exact same mods as me and the only difference is the racing wheels. It would have to be damn near a gutted 3000lb car.
12-28-2019, 02:20 PM | #6 | |
Evil Genius of Chevrolet
Gears and drag radials got me into low 12's on a L99 with a tune and some suspension work.
12-28-2019, 02:36 PM | #7 |
Drives: 2013 Camaro SS Join Date: Feb 2017
Same here 12.3 with bolt ons and 3.91 gears.
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 |
12-28-2019, 03:08 PM | #8 |
But you guys have maximized your bolt ons in the process which is gonna set you up for really good times when the bigger mods go in.
12-28-2019, 03:56 PM | #9 |
Also, Merc doesn't put every single mod on there every time; many people's mod list would never fit in one row like on the list, so just the main ones go up. You'd be more likely to get a bit better big picture (track conditions, race weight, mods, etc) by going to the original post of the timeslips
12-28-2019, 04:11 PM | #10 | |
12-28-2019, 05:01 PM | #11 |
I believe I've found the thread that will answer your questions. Just had to dig a bit. Enjoy
https://www.camaro5.com/forums/showthread.php?t=392273
12-28-2019, 06:18 PM | #12 | |
Your car is dialed in so nice. I hope mine does as well when she's done.
12-28-2019, 06:48 PM | #13 | |
12-28-2019, 07:54 PM | #14 | ||
