BeckyD @ James Martin Chevy
Old 08-05-2018, 02:44 PM   #1
Kevin_S17
Kevin_S17's Avatar
Drives: 2017 2SS M6 Vert Summit White
LED for 2LT non RS
I’m looking for recommendations on LED bulbs for my 2017 2LT. Preferably bulbs that fit inside the headlight housing without modification and do not cause any error codes. Thanks in advance.
Kevin_S17 is offline   Reply With Quote
Old 08-05-2018, 05:33 PM   #2
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
There is a lot of great information out there on LED conversions. There are also a lot of LEDs that will lower you visual range at night to do your research.
dpevans is offline   Reply With Quote
Old 08-07-2018, 02:12 PM   #3
Kevin_S17
Kevin_S17's Avatar
Lumens - How many?
I've settled on 6000k color range. I know that I want canbus ready. I don't mind drilling a hole in the cap if I need to. Do you have any recommendation on total Lumens? Is 6000 enough or should I be looking at a higher output?
headlight bulb, led
