08-10-2017, 10:55 AM | #1 |
Drives: 2017 1SS 1LE Silver Ice Metallic Join Date: Jun 2016
After "goo gone"
After using the goo gone method to de badge, do you use detailed spray to get the goo gone off? Do you need to reseal or reapply the top coat? Do a full detail process again? What's recommended?
08-10-2017, 10:58 AM | #2 |
You should wipe area with diluted IPA. Then reapply sealant.
08-10-2017, 11:50 AM | #3 |
Drives: 2017 ZL1 Join Date: Oct 2016
I used a isopropyl to cut the goo gone oil and then waxed the area (liquid glass). I dont think the googone will cut into the clear coat or anything.
BTW, isnt that pita job?!
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
08-10-2017, 11:56 AM | #4 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Yup, IPA, or any soap....
08-10-2017, 05:06 PM | #5 |
I haven't started it yet, just getting set up to do it properly. Thank you!
08-10-2017, 05:12 PM | #6 | |
The badge will almost fall off. |
08-10-2017, 06:48 PM | #7 | |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Come back an hour after and it comes right off. Works well for sticker residue too.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
08-10-2017, 06:49 PM | #8 |
Very smart.....
08-10-2017, 06:51 PM | #9 |
1) Heat gun or blow dryer to heat up the badge first.
2) Dental floss or fishing line to remove after heating up. 3) Adhesive remover (Goo Gone). Rapid Tac Rapid Remover works best. 4) Clean residue with soap/water. 5) Machine polish the area to remove any micro-marring or "ghosting". 6) Wipe down with IPA or Carpro Eraser, apply protection. Takes about 15 minutes.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. Last edited by Joe M 2012 2SS; 08-10-2017 at 07:04 PM. |
08-10-2017, 08:04 PM | #10 |
That rear emblem on the SS literally took my 1.5 hrs to get off and put new one on. That adhesive was like super glue.
