Old 08-26-2019, 04:47 PM   #15
oldman
Drives: SS 6 speed of course
You could always go for full cat deletes and weld in your own highflows.
http://www.neweraperformanceparts.co...ete-pipes.html
Problem being, everybody is going to do this and not order highflows and complain about the drone, and for me the lack of low speed tip in torque with the M6 on my combination. My setup needs cats or is sounds like shiznit and low speed tip in sucks. Don't have any comment about anybody elses setup.
oldman is offline   Reply With Quote
