Vararam
Old 11-12-2019, 12:45 PM   #1
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
Done with glass cleaner
For years I've been using foaming glass cleaner which actually worked excellent, streak free perfection.
I have meguiars waterless wash which I noticed that the bottle mentions to use on glass too, I previously only used it to spot clean paint in between washes.
First I just wash the glass along with the rest of the car using my wash mitt. Dry the glass completely.
This stuff is awesome on glass and being a light wax it also has a water repelling effect, I use a micro fiber towel to apply and a separate dry one just to buff out. No streaks!
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
Quicksilver2SS is offline   Reply With Quote
Old 11-12-2019, 04:52 PM   #2
mikeman
Drives: 2015 Camaro
Do you boil the microfibers before you use them on the glass? If you don't, you will get fibers all over the glass surface which looks terrible in the sun.
mikeman is offline   Reply With Quote
Old 11-12-2019, 06:17 PM   #3
Quicksilver2SS
No, didn't have any problems with that, might depend on what brand?
Old 11-13-2019, 08:50 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What about on the inside of the windshield does it get that hazy film off?
Orange Krush II
Old 11-13-2019, 03:08 PM   #5
Quicksilver2SS
Haven't tried inside yet
Old 11-14-2019, 06:30 AM   #6
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
I use a 50-50 water/rubbing alcohol mix (you can buy this pre-mixed at just about any drugstore or Walmart) and a Mr Clean Magic Eraser for the inside glass. Get the eraser wet and lightly wring it out. Spray the mix on the eraser and rub it into the glass like you're applying a polish or wax. Take the first cloth to mop up the majority of the IPA/water mix, then use a second cloth to buff the glass. It comes out perfect for me, and I'm a smoker.
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
