TireRack
Old 04-13-2019, 05:57 PM   #1
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
How bad is coin op car wash water?
The coin op car washes recycle the water (except for the low pressure final rinse I've read).
So how bad is it for the cars paint to use recycled water?
I usually do waterless washes (apartment dweller), but occasionally it would make things easier with a high pressure pre rinse to knock off the dust.
Thanks!
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
Quicksilver2SS is offline   Reply With Quote
Old 04-14-2019, 10:49 AM   #2
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
I can't imagine there is anything wrong with it, but I am sure someone more knowledgeable will chime in.
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 04-15-2019, 02:14 PM   #3
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
My guess is it's way safer than waterless washing for anything beyond light dust. When I lived in an apartment I used a coin op frequently to rinse of the car before a doing a rinseless wash back at home.
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 04-15-2019, 03:46 PM   #4
Quicksilver2SS
Thanks!
Old 04-15-2019, 05:41 PM   #5
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
I wouldn't drink it
Automatic washes recycle too. It is supposed to be filtered, of course.
Usually the water commission requires that, they can't handle the amount of water and waste otherwise.
Ready-mix plants recycle the water (and sand and stone) from left-over mix, though I would be leery about washing a car with that.
2011 1SS/RS LS3 CGM
Old 04-15-2019, 11:59 PM   #6
Silveradoss573
Drives: Camaro 1LE
I've never seen anything bad with the car washes I use around my area. My thoughts are you're fine and have nothing to worry about but don't use the scrub brushes.
Silveradoss573 is offline   Reply With Quote
Old 04-16-2019, 11:48 AM   #7
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
I use coin op washes all the time, just never the brush, luckily mine has high pressure soap
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 04-16-2019, 12:24 PM   #8
Davij217
Davij217's Avatar
Drives: Camaro
Depends on the softener.
Davij217 is offline   Reply With Quote
Old 04-18-2019, 07:38 AM   #9
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
The water from the pay & spray car washes can leave water spots if left to dry.
If your just wanting to knock whatever loose contaminates on the surface before doing a waterless wash, that is fine.
However a Rinseless wash would be a much safer option for your paint.
The soap used at the Pay & sprays is generally cheap non ph-neutral, and will strip wax/sealant so I'd avoid it.
Get yourself some good microfibers and a couple 5 gallon buckets with lids, and do a rinseless.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 04-18-2019, 09:01 AM   #10
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
As long as it doesn't have brushes I would say you are okay.
ZEN357 is offline   Reply With Quote
