Vararam
Old 01-17-2019, 01:44 PM   #1
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
Wheel hop with normal driving
Bone stock 2013 Camaro SS LS3, this car wheel hops unless you feather the gas/clutch, especially on cold or rainy days, we're talking normal driving where you would just barely chirp the tires NOT any 5000 rpm launches.
I'll be checking the rear shocks first and replacing the original tires (14k miles) soon.
Trailing arms with poly bushings are tempting but is this normal for the car to be that wheel hop sensitive during normal driving?
Thanks
Quicksilver2SS is offline   Reply With Quote
Old 01-17-2019, 04:21 PM   #2
Avenging Orange
Avenging Orange's Avatar
So, you say you're "kinda" getting on it in the rain and cold? What rpm are we talking here?
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 01-17-2019, 05:37 PM   #3
Quicksilver2SS
1500 rpms, just enough to break the tires loose
Old 01-18-2019, 07:40 AM   #4
Avenging Orange
Obviously you have something whacky going on there. I'd start with shocks, springs, sway links, etc. Any grinding/banging when this occurs?
Old 01-18-2019, 11:53 AM   #5
jethrobandit
jethrobandit's Avatar
Drives: 2013 Black 2SS
I'd say that would be abnormal behavior at that rpm. I have issues with it too and am about to do a bunch of work to eliminate it (bushings thread right below yours). But, I generally don't have issues with it until I'm really getting on it at launch (3000-4000). Considering cold and rainy with the typical concrete surface there in Sac, I would expect some extra bump and hop. But that sounds like shocks/springs or some breakage in the toe/trailing linkage to me. It's more than I experienced in similar surfaces in Dallas.
jethrobandit is offline   Reply With Quote
Old 01-18-2019, 04:46 PM   #6
Quicksilver2SS
Shocks show a little trace of fluid, definitely no marks from bottoming out, no grinding banging noises at all. Just got oil change today everything looks good up on the lift.
Tires are original and will be replaced soon as they are dated 2012 lol, 14k miles on em. Guess I'll see what happens then.
Thanks for the replies!
