12-15-2018, 07:16 AM | #15 |
Drives: 1LEs Join Date: May 2009
Rear stud change is not the cake walk the fronts are. I agree on the spacers with proper thread engagement.
12-15-2018, 07:51 AM | #16 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
12-15-2018, 08:12 AM | #17 |
Drives: ISO ss 1le Join Date: May 2018
12-15-2018, 08:14 AM | #18 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Color me crazy but, I’d just rather get wheels with the proper offset than to use a spacer. Also, I thought I saw a thread about how much of a pain in the ass it was to swap out studs on these cars...
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
12-15-2018, 08:33 AM | #19 | |
The front studs are beyond easy. All you need is a sledge or dead blow, a few washers and a lug nut. There was a guy on here that took his whole brake assembly off and pulled the hub, super unnecessary. Since we don’t really have a brake shield our studs just pop right out the back. Fronts take 10 mins. Easier than a pad change |
12-15-2018, 08:35 AM | #20 |
You’re not crazy, but then you can’t run a true square wheel/tire package without spacers. The front studs are the easiest I’ve ever done. You don’t even have to remove the brake rotor or caliper. Rear studs are always more of a challenge, but you don’t need a rear spacer with the Apex setup.
12-15-2018, 08:46 AM | #21 |
Drives: ZL1 A10 Join Date: Dec 2017
I am also not a fan of running hub centric rings to get a wheel to fit. As a long time user of Apex wheels on my M3 track car it is very disappointing to me that Apex has not stepped up to the plate and given the Camaro community some real wheel options.
My rides:
2017 Camaro ZL1 A10 2015 Jeep Grand Cherokee Diesel 2012 Audi S4 1992 Porsche America Roadster 1990 BMW 325Ic |
12-15-2018, 09:01 AM | #22 |
You’ll be pleasantly surprised in a few months then
12-15-2018, 10:10 AM | #23 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
That would be great...Apex has been singing that song for 18 months now.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
12-15-2018, 10:22 AM | #24 |
Drives: 1LE Join Date: Sep 2017
18 here.
10.5 F 11.0 R But have two sets so could run 10.5 square Ford Motorsports Studs. This is before I got more aggressive with a camber and Hoosiers which I no longer run https://youtu.be/uKTw78hKCmg |
12-15-2018, 10:30 AM | #25 |
Some pic. Thick spacers for sure. Doesn't seem to affect my driving
12-15-2018, 04:45 PM | #26 | ||||
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
I got my Apex track setup on clearance for like $250/wheel. I'm not going to complain about running hub rings when the wheels are cheaper than the tires |
12-15-2018, 04:49 PM | #27 |
This is my 18x10.5 with 295/30/18 square setup. Using 12mm spacers in the front, no strut grinding, maxed out camber.
12-16-2018, 06:27 PM | #28 | |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
Thanks for uploading the pictures.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
