05-04-2022, 02:54 PM | #1 |
Drives: 2014 camaro S's l99 Join Date: May 2015
ProEFI 128 c6 corvette/ Gen 5 Camaro $4000
ProEFI 128
Application starter kit for Gen 5 Camaro SS/C6 Corvette Includes everything that comes from ProEFI plus extras Comes with Wideband sensors, fuel and boost pressure sensor and IAT sensor, flex fuel sensor with fuel line fittings and harness) In addition to the starter kit is the following: 1) 2000psi bottle pressure sensor with enough wire to put sensor back in trunk by the bottle. 2) Custom 5 position boost knob unit. •can choose from 5 different boost settings on the fly •4 lamps in housing that can be selected for various indicators - my setup was 1)shift light 2) nitrous activated 3) traction control on 4) traction control active. 3)Boost solenoid and wires terminated from main harness 4)Perfect tuning gauge with vent gauge pod - this gauge is awesome! Taps into the canbus wires from the ProEFI and you can choose every sensor to view, set multiple alarms and several different display screens. 5)Flex fuel sensor and wires terminated from ProEFI harness Last edited by stodd347; 05-04-2022 at 05:15 PM. |
05-04-2022, 07:24 PM | #2 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Will that control a 6L80 trans?
05-04-2022, 09:42 PM | #3 |
Yes sir, it fully supports 6l80e
07-09-2022, 06:49 AM | #4 |
Price reduction, $3999
Seriously, I am open to reasonable offers. |
