Old 03-27-2012, 09:43 AM   #1
SGTMiller278CAV
Silver Surfer
SGTMiller278CAV's Avatar
Drives: 2011 Camaro LS M6
Creaking sound when I start moving (Help)
So first off, 2011 LS M6.
When I start rolling from a stop, I can hear a slight creaking sound coming from the rear of the car. I have crawled under the car and everything seems to be "ok". nothing loose or snapped or leaking of any sorts. I cannot tell if it is doing it at higher speeds due to my loud exhaust. It only happens when I first start rolling for about one second.
It is very noticeable from outside the car (let the wife drive it so I could hear it).
Is there a TSB for something like this? anyone ever experience this with their Camaro?
Please
SLP Loudmouth 1 Exhaust / Magnaflow Resonated X pipe / 22 Inch AAC Dynamic Scanner / Reverse Rally Stripes / LS badges (emblempros.com) / Gill Decals / Flat Black SS Rims / SS Rear Diffuser / Flat Black Spoiler / Heritage Grill / Custom Painted Tail Light Bezels / Custom Painted Engine Cover / Plati Dipped Trunk Lid
SGTMiller278CAV is offline   Reply With Quote
Old 03-27-2012, 09:56 AM   #2
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
It could be your exhaust banging around. The person who did the install in mine didn't tuck the exhaust up well enough and found out that it was causing the same creaking noise to happen with me.
mcdoogle6969 is offline   Reply With Quote
Old 03-27-2012, 09:58 AM   #3
SGTMiller278CAV
Silver Surfer
Thanks! I will tuck the exhaust in a little further and see if that helps.
Old 03-27-2012, 10:00 AM   #4
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
I presume that you've tried narrowing down the list of suspects...
Park on a steep hill, engine off... release the brake, see if you get it. Try it engine on, engine off, forward, backward, in gear, in neutral...
Try replicating it with light "brakestanding."
Try rocking/ bouncing the car by hand... see if it's suspension issue (bushings can creak)...
Make sure there are no coffins with stirring vampires in the trunk.
Scalded Dog is offline   Reply With Quote
Old 03-27-2012, 10:02 AM   #5
Scalded Dog
Drives: 2011 1LT
Exhaust DOES sound like the most likely culprit... if it were me, I'd try tightly wedging something in various places along the exhaust route, to see if the location can be pinpointed... don't forget to remove the wedge material before hitting the Autobahn, though!
Old 03-27-2012, 10:31 AM   #6
SGTMiller278CAV
Silver Surfer
Just gave the car a run-around and I am almost sure it is the exhaust. and also no vampires lol.
Old 03-27-2012, 10:32 AM   #7
2012SS
2012SS's Avatar
Drives: 2012 V.R. Camaro SS, '67 Camaro
Not sure what you mean by "creaking", but I installed my exhaust myself and accidentally bent the heat shield through the tunnel enough that it was hitting the U-joint on the driveshaft close to the transmission. For the life of me I coukdnt figure out what it was, finally I put the rear up on jacks and turned the tires. This sounded closer to a "tapping" though. Does your sound have the frequency of any drivetrain movement? Mine was making the noise at a relative speed to the driveshaft so that's what helped me to track it down.
2012 Camaro SS Victory Red, CAI intake, Flowmaster Outlaw Catbackhttp://i5.photobucket.com/albums/y186/69hotrod/5ecc4bef.jpg
2012SS is offline   Reply With Quote
Old 03-27-2012, 10:32 AM   #8
Dylan88
UCF Knights
Dylan88's Avatar
Drives: 2012 2LT RS
mine does it also. will have to look at the exhaust.
Dylan88 is offline   Reply With Quote
Old 03-27-2012, 11:07 AM   #9
SGTMiller278CAV
Silver Surfer
the best way I can explain the creaking (fixed now) is when you hear a 1980 junkyard POS driving beside you, you hear a creaking like someone crawling into an old bed or (vampire coffin from a bloodsucking movie). it is a very odd sound.
but on another note took my car to the FMS shop, (active military so have a full time shop open all the time). loosened up the exhaust, recentered, pushed the tips in more, and impacted the living hell out of it.
creaking = gone.
Old 03-27-2012, 01:28 PM   #10
mcdoogle6969
creaking = gone.
Glad that helped you!
So let's set this straight on what gives it that v8 sound CamaroC-17 5th Gen Camaro SS LS LT General Discussions 112 01-03-2017 11:06 AM
Corsa Performance Catback Exhaust– Perfect Sound! (For me) MichaelM Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 05-02-2010 04:50 PM
Surround Sound Help! T! E! X! A! S! Off-topic Discussions 3 01-24-2009 05:55 PM
