Old 06-19-2015, 01:11 PM   #1
CamRamRo
CamRamRo's Avatar
Drives: 2014 TR Stingray M7
2016 Camaro LS Base?
http://www.camaro6.org/forum/297-6th...camaro-ls.html
Steel wheels, manual windows an door locks, black plastic front fascia... Interesting.. Expected to start under $20k.
Literature from above link:
"Chevy is leaving no stone unturned in its quest for Mustang crushing volume. Such extremes is Chevy taking that they will offer a -LS trim for the Camaro which will slot in below the 1LS and 2LS packages.
Black plastic cladding adorns the front and rear bumpers, sill moulding, mirrors and door handles. Paint options will be limited to Hyper Blue, Nightfall Grey, Red Hot, Black and White. Steel wheels (available in black or unpainted steel ) come pre wrapped in Dunlop Graspic DS-3 winter tires, this is Chevrolets response to snowbelt area owners complaints that P245/55R18 Summer rubber is far too unreliable in as little as 2 inches of snow.
The interior is rumoured to include a front bench seat with hideaway arm rest, its a subtle touch of retro on Chevrolets part. AM/FM radio, manual windows and heat round out the rest of the standard interior equipment."
Prices are expected under $20,000
2016 Camaro -LS
Mechanical
Engine, 2.0T 4 Cylinder
Transmission, 6-speed manual (STD)
Differential, limited slip
Rear wheel drive
Alternator, 150 amps
Battery, maintenance-free with rundown protection and retained accessory power
Suspension, Sport
Steering, power, variable ratio
Brakes, 4-wheel antilock, 4-wheel disc (Single piston front brakes with super corner rear brakes.)
Exhaust, single outlet, unpolished
Interior
Audio system, AM/FM radio
Antenna, integral rear window
Seats, Front Bench with hideaway arm rest
Seat adjuster, driver 4-way manual (fore/aft, up/down) with manual recliner
Seat adjuster, front passenger 2-way manual (fore/aft) with manual recliner
Seat trim, LS Cloth seat trim
Console,hideaway armrest
Floor mats, carpeted front
Steering wheel, 3-spoke, urethane
Steering column, manual rake and telescopic
Instrumentation, analog includes speedometer, tachometer and fuel gauge
Door locks, Manual
Windows, Manual
Trunk release, remote, located on driver-side
Theft-deterrent system, PASS-Key III
Optional Air conditioning
Air filtration system with pollen filter
Defogger, rear-window, electric
Glovebox, lockable
Cup holders, 2 front
Map pockets, front doors
Mirror, inside rearview manual day/night
Visors, driver and front passenger vanity mirrors, covered
Lighting, front reading lamps
Lighting, interior with illuminated entry and theater dimming
Coat hooks, driver- and passenger-side rear
Shift knob, urethane
Exterior
Wheels, 16" (40.7 cm) steel (STD)
Tires, P245/55R16 touring, blackwall, winter
Tire sealant and inflator kit in place of spare tire
Molding, Black roof ditch
Fascias, front and rear black plastic
Moldings, black plastic
Hood blanket
Headlamps, halogen composite with automatic exterior lamp control
Mirrors, plastic manual adjustable
Wipers, front intermittent
Door handles, black plastic
Safety
Daytime Running Lamps within low beam headlamp
Air bags, dual-stage frontal
Safety belts, 3-point, all seating positions
Safety belt pretensioners driver and front passenger
LATCH system (Lower Anchors and Top tethers for CHildren) for child safety seats
Trunk emergency release handle
Last edited by CamRamRo; 06-22-2015 at 05:06 PM. Reason: Added literature from link
CamRamRo is offline   Reply With Quote
Old 06-19-2015, 01:14 PM   #2
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
That's a good one..
ChefBorOzzy is offline   Reply With Quote
Old 06-19-2015, 01:21 PM   #3
mt3130
Drives: Coupeless :(
I'm not sure I believe this. We have seen the dealer playbook, and this trim isn't mentioned. Also, some of the features listed aren't available on any car that GM makes at this point, and you would think the car would have to be completely parts bin made to be profitable, such as a bench seat.
mt3130 is offline   Reply With Quote
Old 06-19-2015, 01:24 PM   #4
mako22
mako22's Avatar
Drives: 2017 HB 2SS
have to call BS on this one
mako22 is offline   Reply With Quote
Old 06-19-2015, 01:26 PM   #5
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
No source=BS
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3
"Voices in your head are not considered insider information."
3800 Status - 6/16/16 (Built!)
6000 status - 6/29/16 (Delivered!)
SuperSound is offline   Reply With Quote
Old 06-19-2015, 01:28 PM   #6
CamRamRo
CamRamRo's Avatar
Not sure where this source came from... My initial thoughts were that this was BS also. My second thought was, "Let me put this on Camaro6 and see what the Gurus think!"
Old 06-19-2015, 01:33 PM   #7
fastball
Drives: 2017 Camaro 2SS 6MT
Yeeeeah, no.
The bench seat thing gives it away. Acutally, the bench seat, the no A/C, steel wheels, and unpainted bumpers all give it away. Someone thinks they're funny!
They wouldn't build a car without power windows and locks today if they wanted to - that would actually INCREASE the cost of the car, to make manual windows and locks optional, or standard..... or whatever.
Just keep this in mind: part of the surcharge for the 5th gen Camaro Z28 is to cover the extensive wiring and ECU changes required to make A/C optional.
fastball is offline   Reply With Quote
Old 06-19-2015, 01:57 PM   #8
Bassment
Drives: 2016 Red Hot 2SS M6
LOL I almost believed it until it said a front bench seat. And no power locks...
Bassment is offline   Reply With Quote
Old 06-19-2015, 02:10 PM   #9
KMPrenger
KMPrenger's Avatar
BS
Old 06-19-2015, 02:33 PM   #10
Iroc_Z28
Iroc_Z28's Avatar
Drives: 2017 1SS 1LE
haha, Hood blanket??....i wouldn't trust this
Iroc_Z28 is offline   Reply With Quote
Old 06-19-2015, 02:49 PM   #11
BowtieV8
Longtime Chevy Girl
BowtieV8's Avatar
Drives: Not a VVette…yet
Never fell for it. A "base" but it has the RS headlights? Yeah...no.
BowtieV8 is offline   Reply With Quote
Old 06-19-2015, 03:09 PM   #12
xgnxs
xgnxs's Avatar
Drives: 2005 Cobalt Base - 5 speed
Winter tires standard? Bench seat? Manual windows and locks? Optional AC? Yeah. Sure. Not happening.
xgnxs is offline   Reply With Quote
Old 06-19-2015, 04:00 PM   #13
Jeffro19
Jeffro19's Avatar
Drives: 2018 ZL1 6M, Silverado High Country
Haha very funny I thought April fools passed already....
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof
2019 Silverado High Country, Daily Driver
Jeffro19 is offline   Reply With Quote
Old 06-19-2015, 07:23 PM   #14
Drives: 2023 GMC Canyon, 2020 Colorado
BS.
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
