08-20-2023, 02:04 PM | #1 |
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert Join Date: Sep 2019
Well, I learned one thing about non-OEM bulbs...
...when I replaced a burnt signal light on the back with an aftermarket LED light. While it does function the way it's supposed to now, it is still sending the fast-blink signal to the info-center between the speedo and the tach.
Dammit.
"Never cough into a full ashtray."
08-20-2023, 02:13 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
May need some sort of external resistor to increase resistance since LED's will have less resistance than HID, making the car think there's a blown bulb.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
08-20-2023, 02:14 PM | #3 |
Dammit.
08-20-2023, 06:50 PM | #4 |
Might be able to add a resistor in parallel. Works on some vehicles.
08-20-2023, 08:03 PM | #5 |
Fast Cars and Old Guitars
So does the LED blink fast? Or normal but the dead bulb indicator just blinks fast?
08-20-2023, 09:26 PM | #6 |
Both the LEDs and the dead bulb indicator blink fast.
08-20-2023, 09:27 PM | #7 |
No, just going to gut it up and buy OEM bulbs.
08-20-2023, 10:22 PM | #8 |
Resistor solves the problem.
3-4$ from electronics store. Last edited by chevy pilot; 08-20-2023 at 10:56 PM. |
08-21-2023, 12:31 AM | #9 | |
Drives: 2SS/RS Join Date: Sep 2008
You will either have to splice in a resistor, don't remember exactly ohm is needed, or buy quality brand that has the resistor built into the light already. |
08-21-2023, 07:34 AM | #10 |
Here is a link. I would shop around though. You might also find bulbs with them built in.
https://www.diodedynamics.com/led-re...-kit-pair.html
08-23-2023, 08:24 PM | #11 | |
And thanks to the others who made this suggestion!
