08-06-2022, 05:57 PM | #1 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
Just finished build and dyno…..
We just finished my build. Build is as follows: CSP long tubes, mid pipe no cats, awe touring exhaust. K&N air intake, 95 mm TB, flex sensor, stage 2 BTR cam, stock heads, Katech oil pump, comp cams limiter, c5r chain, tcm unlock and tune, jms voltage booster, 10% lower with ATI, and all cam supporting mods. On 93 car did 630 tire, on E55 car did 690 tire. Over all I am pretty happy with the results. I am only making 10- 10 1/2 pounds of peek boost. Would you guys suggest going to a 15% lower and running a lower blend of E for some more boost and power? My next step is either race port stock 1.7 with 103 or a 2650. Give me some feedback please.
08-06-2022, 06:16 PM | #2 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
Those are decent numbers. I would recommend spending a good amount of time driving it and see how well it does with heat especially in the hot summer. it's been 90*F+ near me lately. It's the perfect time to run it hard and see how well it holds.
I've had this thing on the ragged edge and I honestly think that 600-700hp at the wheels is pretty much the most you can get away with and have the car still be manageable. More power is great but it's terribly difficult to put it to the ground. |
08-06-2022, 07:05 PM | #3 |
Having FUN in the SUN...
sounds like a healthy build... would love to hear some clips of the idle!
08-06-2022, 07:15 PM | #4 |
Need more pics and videos
08-06-2022, 08:09 PM | #5 |
Red Bull
On the dyno he didn’t give it a ton of cool down time. He likes to dyno them like they are actually on the street. With that cam and long tubes I am still at stock boost levels….. just a lot more power and efficiency. He said with a long cool down we could have gotten another 10-15 at the tire for a glory pull. �� Let’s see how she does in the next few weeks. I also have a weld full drag pack if I need it for more traction. The 555R2s are doing a pretty good job currently on low pressure.
08-06-2022, 08:28 PM | #6 |
I'm partial but 2650 Maggie all the way. Lower IAT's more power in reserve, just go big and kick some ass.
08-06-2022, 09:08 PM | #7 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
How the hell is my tire HP higher from just adding the 2650 compared to all the mods he just did? Does the 2650 make that much of a difference compared to a cam and long tubes? Don’t mean to derail your thread, just confused as to why people just don’t go straight to the 2650 first and than other smaller mods later….
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
08-06-2022, 10:39 PM | #8 | |
2016 NFG 1SS A8
08-06-2022, 10:41 PM | #9 |
Red Bull
I am also still at 10 pounds of boost. The motor is very efficient with this setup. I wanted to fix some reliability issues first as I did a few mods along the way. The oil pump, timing chain guid I changed to the LME wishbone, the lifters and trunion upgrade. It is now setup for the last step in HP mods. My setup with 2650 and aux pump on E50-60 should be around 850-875. That’s my plan. That’s why I decided to go this route.
08-06-2022, 11:22 PM | #10 | |
If you just swap the stock blower for a 2650 and basic bolt ons, headers, TB, intake etc its probably making 15-16lbs of boost with the stock 90mm pulley. Hes only making 10, another 5lbs of boost is probably good for 75-90 whp or so. I put the 2650 on my car, headers, intake, 103TB and it made 680whp.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
08-06-2022, 11:34 PM | #11 | |
Petro-sexual
And nice numbers! Video or it didn't happen!
08-08-2022, 02:14 AM | #12 |
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
Subbed
08-08-2022, 12:09 PM | #13 |
Drives: 19' SW ZLE Join Date: Jun 2022
Ditto! Looking at similar build to this. And will probably be going straight to a 2650.
Summit White 2019 Camaro ZL1 1LE
- Rotofab Big Gulp - CSP LTs Past: - 02' SS Procharged (stolen) - 01' Z28 (sold) |
08-08-2022, 12:17 PM | #14 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
Next is 2650, eddy or maggie. Stockish boost on a 2650 will be amazing with what you have
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
