09-07-2021, 11:39 AM | #1 |
Drives: Camaro 1LE Join Date: Jan 2020
Radiators
Anyone here use Mishimoto dual core radiators? Not looking to break the bank. Any budget friendly recommendations would be appreciated
09-08-2021, 10:09 AM | #2 |
I'm running a Mishi radiator and it's been great at keeping the temps below 220 on a hot day at the road course.
The install was easy and painless too. I have zero complaints.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
09-08-2021, 11:16 PM | #3 |
My engine oil gets hot before the radiator when I'm driving hard. I heard Mishimoto makes a great upgraded oil cooler. That's what I'd recommend. My new AC Delco OEM radiator does a good job of keeping temperature s low. I've also replaced water pump, radiator and fan.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
09-09-2021, 03:58 AM | #4 |
Drives: Camaro SS Join Date: Mar 2021
Mishi in mine, would definitely recommend. Want quality you gotta spend a few more bucks imo
09-09-2021, 08:42 AM | #5 |
A number of guys have used Champion radiator. They will even customize things, which is why I was looking at them. If I ever go to a bigger turbo, I will have to relocate the upper hose.
09-09-2021, 08:53 AM | #6 |
Tri-County Camaro SWFL
Just found my radiator was leaking. Bought a mishi. Have yet to install it
09-09-2021, 11:13 AM | #7 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I put a Mishimoto in mine. I had to massage it to make it fit properly. But it looks good. Hopefully it lasts.
More to come. |
09-27-2021, 03:12 PM | #8 |
Just installed mine today. Everything went very smooth surprisingly. So far so good. Coolant temp hasn't gotten over 210 but I also haven't been beating on it.
Thread Tools | |
