08-03-2022, 06:27 PM | #29 | |
'20 ZL1 1LE A10,
08-04-2022, 07:53 AM | #30 | |
Petro-sexual
I don't drive the car like a lunatic most of the time, so hopefully the A10 will last God be with you and yours
08-04-2022, 09:23 AM | #31 | |
GM has the torque ratings listed...the 10l90 is rated for 663ft/lbs. Then there is a 10l90-E crate transmission that is rated for 715ft/lbs. The 10l80/10r80 that both GM and Ford use is in the SS and GT rated for 590 ft/lbs.
2016 NFG 1SS A8
a10, built trans, transmission |
