AWE Tuning
Old 05-22-2022, 05:04 PM   #43
Smokin19
Drives: 19' ZL1 A10, w/pdr
Originally Posted by SOCAL.M6.ZLE View Post
Correct... Ted includes that in his base cam package.
I just figured there were other items i should do, and wanted the teams feedback.
So here is the updated list...
JRE Cam Package...
CAM: 222/234 .635/.635 114LSA 112 ICL +32%
Includes: Pushrods, lifters, gaskets, bolts, etc...
Then i will ad...
1. MM Catch Can
2. Blower Spacer and Blanket
https://fiinterchillers.com/product/...spacer-plates/
3. Green Gates Belt
4. 160 stat.
5. Katech VVT delete + Billet cover + C5R chain
https://shop.katechengines.com/produ...oiling-system/
6. ATI Balancer + 15% OD Pulley
Together that is about $5k which is my budget... so the ported blower will need to wait.
Anything else minor that I am missing?
I can only give an uneducated opinion, others know better but, should you be looking at more of a 38% fuel cam. Further down the road you might need more high side fuel and that would include low side also. The cam should be the right one from the git go because of the cost of pulling the engine. Again, others know better.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 05-22-2022, 05:50 PM   #44
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Good catch... Ill ask... might be a typo.
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
SOCAL.M6.ZLE is offline   Reply With Quote
Old 05-22-2022, 06:09 PM   #45
SOCAL.M6.ZLE
I know everyone hates these questions... but what do you think I would pick up doing the JRE cam + ATI with 15% OD Pulley ?
I'm already at 650rwhp / 650rwtq on E50 on a 95 degree day with 150 degree MAP temps... I was running out of fuel on the high side, which is why im doing the cam... Considering I have the JMS on the low side... do you think the cam would get me to 725rwhp after a tune? more or less? Just trying to run a simple $ to HP calculation.
Old 05-22-2022, 06:24 PM   #46
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
You’ll gain 75whp from the cam on the high end of rpm range.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Camaro1973 is offline   Reply With Quote
Old 07-16-2022, 04:57 PM   #47
SOCAL.M6.ZLE
cant wait... Just need a few more bucks and a pinch more confidence
Anyone have a lift plate they want to sell me?
Old 07-28-2022, 10:03 AM   #48
SOCAL.M6.ZLE
Project Update.... PARTS have been ordered.
The following are on their way...
- JRE Cam Package with valve-train upgrades
- ATI Balancer with 15% OD Pulley
- Synergy 2 gallon fender tank
- Might Mouse WILD Catch Can
- Katech Oil Pump
- Katech Cast Covers and Coil Relocation Kit
- Katech VVT Delete Front cover
- Katech C5R Chain
- Banks iDash Gauge
- Velossa Tech Ram Air Mouth
So here is my current debate.
Because I am trying to maximize the fueling from the cam and JMS only... I am wondering if I even need to port the blower and add the 103mm TB.
Perhaps I install the above, test, tune, dyno... and see where fueling it at?
I think I can expect 725rwhp with the above?
Then later... Add a low side AUX pump and the ported blower and turn up the E content? Thoughts?
Old 07-28-2022, 10:40 AM   #49
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I wanna hear with the chop is on that cam when it's installed.
'20 ZL1 Black "Fury"
Old 07-28-2022, 02:32 PM   #50
SOCAL.M6.ZLE
You bet I will... thanks again for everyone's help on this
Man I love this community!
Old 07-28-2022, 02:55 PM   #51
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
- Katech Oil Pump
- Katech C5R Chain
- Banks iDash Gauge
When I spoke with Ted before I installed his Terminator Cam/2650 blower package, I want to believe he cautioned me that the cam or blower by itself would not perform well. Not saying gains wouldn't be seen, just nothing crazy.
I just finished tuning my car with Ted. You might find some of the data helpful. With E50, the car ran 29.5 degrees of timing. Low side fueling held at 70# but the high side dropped to 2400# with IPW of 5.34. The E40 pull saw my high side 2900#, low side 70+# and IPW under 5.
Ted suggested that I keep the E at 40 to be safe. The car is going on the dyno next week. I am going to have them do a pull at E40 and another at E50. I am curious to see the difference.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 07-28-2022, 03:15 PM   #52
Trochoidal
Drives: 2017 Camaro 2SS A8
Nice! This is going to sound good and hopefully you’ll have a video posted in a month or so.
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“
Trochoidal is offline   Reply With Quote
Old 07-28-2022, 04:50 PM   #53
turbo_jimbo
Drives: 2022 ZL1 1LE
This looks fun. Can't wait to see the resuls!
turbo_jimbo is offline   Reply With Quote
Old 07-28-2022, 07:58 PM   #54
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
29 degrees of timing is quite a bit. What rpm is that? Also What’s the timing at e40 compared to e50? If it’s only a degree less we’re talking 10-15hp.
Your INJ pw is perfectly fine but pressure is indeed dropping .
Old 07-28-2022, 09:22 PM   #55
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If your IPW is that low I wouldn't be too concerned about the rail pressure dropping some jmo.... I am surprised you are running out of high side pump before injector unless the cam doesn't have a large enough fuel lobe. I agree with above that the timing Seems excessive, many NA LT1 H/C E85 setups don't run that much.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 07-29-2022, 09:41 AM   #56
SOCAL.M6.ZLE
You bet... I'll try to document with some good photos at the bare minimum, and perhaps a walk around video when done... Stay tuned
