03-03-2020, 08:29 AM | #1 |
400HP used to be enough..
Drives: 2010 2SS rs manual Join Date: Aug 2009
Boost Controller recommendations
I'm probably going to install a boost controller on the Huron Speed twin kit I have. For the people who have done this, did you use one solenoid or two? I think there are advantages to doing it either way, I'm just curious what has worked for other people.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
03-03-2020, 09:01 AM | #2 |
Drives: G8 Join Date: Mar 2012
I use a single solenoid GFB3 on a twin kit. No complaints here
Sent from my Pixel 4 XL using Tapatalk |
03-03-2020, 09:47 AM | #3 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
Dido!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
03-03-2020, 10:35 AM | #4 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
AEM TruBoost is common and affordable. Single port and uses a standard PWM type signal.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
03-03-2020, 12:01 PM | #5 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
A single solenoid may get you about 2x the wastegate spring in boost (e.g., you have an 8# spring, you may get up to 16# boost with the EBC). This is generally fine with a SBE LS3/L99 setup.
A dual solenoid may get up 3-4x the wastegate spring. You will loose precise adjustments when getting high in boost, like adjusting a few WG duty cycle point may get you a larger swing in boost.
03-03-2020, 12:57 PM | #6 |
Dual solenoid eBoost2, love it.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
03-03-2020, 02:01 PM | #7 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
Boostleash pulse controller with built in bump feature. It also data logs each run and shows boost throughout the run.
03-04-2020, 08:17 AM | #8 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
good stuff here guys. Thanks for all the different responses.
03-04-2020, 09:24 AM | #9 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I was using the built in boost controller on ms3. It's a total pos so I'm switching to the boost leash. I'm using co2 as well. Highly recommend using it
03-04-2020, 01:13 PM | #10 |
Drives: T Join Date: Mar 2015
Im on aem tru boost, its really simple and has a scramble option, open loop style controller.
If i could do it over again i'd get an Eboost 2, just to play with boost by gear. |
03-04-2020, 09:55 PM | #11 |
I have the AEM TruBoost currently. Really like it for as simple as it is and use both boost settings A and B, plus have the Scramble hooked up. Overboost protection works well. Easy to program right on the gauge.
Recently I purchased a Cortez. It has a lot of bells and whistles including boost by gear and can control meth, nitrous, secondary fuel pumps, and/or do scramble. I haven't had time to swap out controllers just yet. Expecting it to be really groovy.
03-05-2020, 07:59 AM | #12 |
Thanks for all the responses, everyone. I appreciate the help.
Frank
04-21-2020, 12:30 PM | #13 | |
Drives: 2010 Camaro SS/RS Twin Turbo LSX454 Join Date: Aug 2018
I've been looking at getting a Cortez unit as well but I know very little (nothing) about boost controllers. Can you expand a little on why you decided to go with the Cortez unit? When you get around to installing in please do post. I'd love to have a walk-through of sorts from a Camaro owners pov. |
08-01-2020, 10:14 AM | #14 |
Drives: 2011 Camaro SS Join Date: Jul 2017
I'm installing my EBC this weekend. Where are you guys mounting the solenoid? My turbo kit is the Huron single kit.
