08-08-2021, 05:03 PM | #1 |
Drives: 2021 camaro ss 1le Join Date: Jul 2021
Awe mid pipe with corsa axle backs?
Hey guys! Will a corsa axle back bolt up to an awe x pipe?
08-08-2021, 06:27 PM | #2 |
Drives: 2018 Camaro SS Join Date: Jan 2021
The mid pipe are up front near the cats and the axle back is.... well from axle back. The don’t connect.
Do you already have 1 of these parts? If not whole cat backs are close to the price for both. Sent from my iPhone using Tapatalk |
08-08-2021, 06:43 PM | #3 |
I have an awe catback currently. I consider the xpipe the mid pipe, I call it either or
08-09-2021, 05:10 AM | #4 | |
Yeah if you wanna switch go ahead but since you have the axle back already i’d start with the x pipe. The still don’t connect to the axle back so either way good to go Sent from my iPhone using Tapatalk |
08-10-2021, 04:14 AM | #5 |
Drives: 2017 ZL1 - Hyper Blue Join Date: Mar 2015
I can't say for sure, but I would think it would be close. From previous research I did on axle backs, it looked like most required cutting the stock muffler off in relatively the same location. So in that regard, the Corsa pipe will probably be the right length to reach the AWE x-pipe, or really close. One issue you may have is that the axle backs I've seen have all been 2.75 inch to match the stock x-pipe. Your AWE is 3", but you can get premade adapters online for cheap.
Sent from my Pixel 2 XL using Tapatalk |
08-10-2021, 09:13 PM | #6 | |
Edit: read wrong... you have the cat back. Agree with poster above about diameter being off. Sent from my iPhone using Tapatalk |
