09-21-2022, 05:05 PM | #1 |
Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
Aftermarket Cylinder Head Help
Ok guys, I got my cam spec by GPI but if I go ported heads I have to wait a long time as they have no cores at this time and I don't want the car down 4-6 weeks if I send them my heads.
What aftermarket cylinder head options would be good for my small speced vvt cam like mine? Trick flow, AFR, darts? I assume I want the highest flowing smallest rectangular port ls3 head as I won't have a huge cam and bigger ports are not necessary and not great for low and mid range torque. When I was young AFRs always had the best flow numbers with modest port size but I am out of the loop with the LS3 type heads. I am being realistic and assume 20hp with an aftermarket head would be about it with such a small cam..... what are my options. Thanks |
09-22-2022, 05:14 AM | #2 |
All will fo fine from the top manufacturers. I went PRC.
09-22-2022, 10:06 PM | #3 |
RHS seems to be the more budget based heads, PRC is mid range and then AFR are slightly more. From the flow numbers I can find it looks like MAST,AFR and Trick flow are top flow numbers but the trick flows do it will a 255 intake runner. I know from experience that the smallest runner that flows the most is usually best on a street car but I have had AFR heads before and have great faith in them. I will buy the cam set up first I think in the coming weeks.
09-24-2022, 08:27 PM | #4 |
Anyone use these as cast cnc chamber PRC heads? These are a pretty good price for the flow numbers. I am thinking these or go all out with the AFR Mongoose but I don't know if my mild cam will really benefit with a high end head like an AFR over these.
https://www.texas-speed.com/p-7650-p...der-heads.aspx |
09-24-2022, 09:16 PM | #5 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
Frankenstein engine dynamics, do a search.....pretty popular here
09-25-2022, 09:36 AM | #6 |
Tri-County Camaro SWFL
Got them on my car. Great heads
09-25-2022, 01:31 PM | #7 |
Drives: 2011 Camaro SS Join Date: Jul 2019
https://www.camaro5.com/forums/attac...1&d=1664130583
Frankenstein ported heads with stainless valves and their .660 dual spring set up
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
10-06-2022, 04:59 PM | #8 |
1000hp is NEVER Enough!
Head flow comparison. It may help...
1,000hp IS NEVER ENOUGH!!!
11-20-2022, 05:36 PM | #9 | |
Drives: g8gt Join Date: May 2022
11-25-2022, 05:36 PM | #10 |
I ended up getting the GPI Ported ls3 heads
