08-26-2022, 12:00 PM | #1 |
Spark Plug Recomendation - Cammed LS3
Looking for a recommendation for new set of spark plugs
currently using NGK TR6 mods: cold air, LT Headers, under drive pulley, cam and supporting mods Cam specs
CAI Inc, Dynatech 1 7/8 Headers, Dynatech Hi Flow Cats, Magnaflow Competition exhaust, Dyno Tune by SPI Inc., BTR Stage IV Cam, 10% UDP, Hurst Billet Short throw shifter
08-26-2022, 12:34 PM | #2 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Are you currently having issues with the current plugs? A lot of modded guys such as yourself have been using TR6's without issue.
08-26-2022, 01:34 PM | #3 | |
nope not really, they actually have been pretty good. would get the TR6's again, just wanted to see if anyone else had any other recommendations or experience with something better i've inspected them a few times and seems to be normal wear on them. one had a bit of oil on the top part of the threads, but could of been just me not tightening that one plug enough last time i checked them
08-26-2022, 05:48 PM | #4 |
NGK TR6IX's for most cammed guys here..
08-29-2022, 10:21 AM | #5 |
thanks! will take a look at getting a set
08-29-2022, 06:24 PM | #6 |
Got mine from Summit Racing.
09-28-2022, 12:28 PM | #7 |
Drives: Camaro ss Chevy Join Date: Nov 2020
Tr6 iridium
10-05-2022, 05:55 AM | #8 |
Drives: 2010 Camaro SS2 2012 C6 vette M6 Join Date: Jan 2022
Definitely the NGK TR6'S
10-05-2022, 06:46 AM | #9 |
GPI Sales Consultant
Another vote for the NGK TR6IX - have used pretty much the life of my car, multiple cammed setups, always been a good plug, stays clean, good tuning margin for stock-ish compression on 93 octane. The last set I pulled out probably could have just went right back in - but when you have fresh ones sitting right there, you pop 'em in.
AC Delco 41-104 is a good equivalent to the TR6IX for heat range and material.
Got a question about a GPI product? Feel free to shoot me a message! |
10-05-2022, 08:19 AM | #10 |
Regular TR6
09-22-2023, 09:11 AM | #11 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
Are Tr55 ok to run for heads cam ls3?
09-22-2023, 09:14 AM | #12 |
I ran the TR55's when I was just LT's, CAI and a custom dyno tune. When we cammed it my tuner swapped them for the TR6IX's...
09-23-2023, 01:36 AM | #13 |
Give speed a chance
Anti-seize on threads?
09-23-2023, 09:34 AM | #14 |
It don’t come easy.
There are opinions on both sides to use or not use it.
My advice would be, if you’re going to use it…”sparingly” is the key.
Thread Tools | |
