09-05-2022, 08:32 PM | #15 |
Was there a lot more noise with it removed?
09-05-2022, 09:28 PM | #16 |
Not that I could tell...just a lot warmer to the touch than with the cover on.
09-06-2022, 08:02 PM | #17 |
Installed the Ported Throttle Body today and installed new battery at the same time, I used a torque wrench but I ended up stopping at 95 Inch pounds ( Spec is 106 Inch pounds ) since it really felt like it was getting tight. Car started right up but the RPM gauge was gong crazy and I had an ABS and Service Power steering warning message on dash. I unplugged the MAF and TB Plug and plugged them back in and everything went away.
BO's work looks great and working with him was very easy. Thanks again BO. I can't say how it works on the road as it is finally raining here so it will be a few days before I get the car out.
09-06-2022, 09:17 PM | #18 |
Thanx bud. I just happened to run across that new TB when I was cleaning my workshop out. Glad you wound up getting it.
09-07-2022, 06:13 AM | #19 |
Let me know how it runs without a tune. I just Cam'd my car and ROD-MOD w ported tb will be the next little mod over the winter.
09-07-2022, 07:13 AM | #20 |
Will Do, not sure when I am getting the intake I am on the waiting list.
09-09-2022, 05:45 AM | #21 | |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Made 450/420 on stock intake and throttle body. Made 460/435 rod mod/ported TB and carried the power out further rather than falling off.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
09-09-2022, 07:40 AM | #22 |
Ashen That was the only change? Hopefully they send me a good one, It was easier to buy a core from them but it is actually cheaper to buy a new one from GM and send it to them.
09-15-2022, 06:23 PM | #23 |
The Throttle Body works well, the throttle does feel more crisp from the short trip I tried it on.
My Ported Rod mod intake came in a lot sooner than i was expecting, It appears they sent me a Brand new intake, It cam in a GM box and there is not a mark on it and even the inserts do not seem like there ever was a bolt in them and the gaskets all appear new. I Paid for them to send me a Intake ( I was told they send trade ins out ) because I wanted to keep mine, i was going to by a new one and send it to them but I am glad I just let them do it. I have not installed it yet but I plan to in the next couple weeks.
09-15-2022, 06:28 PM | #24 |
Here are some pictures.
09-15-2022, 07:39 PM | #25 |
Everything looks good bud!
09-15-2022, 08:25 PM | #26 |
I have the Heat Shield to install still on the Bottom of the intake.
09-16-2022, 12:42 AM | #27 |
When I bought a new manifold gasket set it actually came with new foam pads to put underneath the intake. But I don't know what order to put the pads on and heat shield or if you even need one or the other.
09-16-2022, 05:06 AM | #28 |
If they are needed I would think it would go on after heat shield. If I pull my intake and it has them I guess I'll put them on.
