09-04-2022, 01:27 PM | #1 |
Drives: ‘10 1SS RS aqua blue metallic. Join Date: Mar 2020
Cam question
Had this cam recommended. 228/234. 627/627. On 112 + 3. LS-3 with 17/8 headers, hi flow cats, Outlaw cat back, CAI, some suspension mods recently also. Don’t track the car and not a daily driver. Drive it 2-3 times a week. Looking for a bit more power and a nice rumble never hurts. Doubt I ever add SC. Stock gears, car pulls really hard in 1st and 2nd. When hitting 3 rd gear on full pedal it doesn’t have a lot. Maybe that’s normal but hoping a cam helps but maybe folks on here can input. Have a safe Labor Day to all
2010 1SS RS LS 3. Aqua blue metallic.
09-04-2022, 10:26 PM | #2 |
Stock gears? Get some 4.10s
I'd go with a stage 4 cam like the TSP F35
09-05-2022, 01:49 AM | #3 |
Depends on whether or not your manual or auto. Cause on that cam if your auto you're at the end of the spectrum for needing a converter. If your looking for something in the lines of those specs, then I would look at a TSP stage 3 or a GPI SS3.
09-05-2022, 02:02 AM | #4 |
It don’t come easy.
It appears that in his sig, it’s a manual.
09-05-2022, 02:24 AM | #5 |
Yeah it's the details that get you. I didn't even notice that. lol
09-05-2022, 02:51 AM | #6 |
Give speed a chance
If you're just using the car for some good cruising along with a few good, hard therapeutic pulls I'd say get a cam that has similar specs to the GM crate 525 HP LS3. A duration of 226 in/236 ex, 110 LSA and a 525 lift that won't cause excessive valve spring stress. Do the LS2 timing chain damper and CHE trunion upgrade for reliability. Throw in some 3.91 gears (factory orig in Z/28 and 1LE) and you're ready to go. Oh, almost forgot. A good, reputable tuner to take full advantage of your new components!
09-17-2022, 04:53 PM | #7 | |
Drives: 2012 SS Join Date: Feb 2016
I agree. I have the howards version of the asa cam except mine is on a 113 lsa, with PAC 1218 springs. This cam, while alot of people look down on it, does what I need it to do. Slightly choppy idle ( get compliments everywhere I go) Pulls pretty hard, yet drives like stock.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
09-25-2022, 11:01 AM | #8 |
Thanks all for the input. I’ve been considering a gear change. I just want to make sure I get a compatible combo of gears and cam. I put 4:11 in my first car, 69 Cougar, and that made a massive difference. But I believe the stock gear were in the 2:70 range so it was a big difference. Going from 3:45 to 4:10 or 3:91 won’t be as drastic but definitely noticeable I’ve been told.
09-25-2022, 05:16 PM | #9 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Any big/aggressive cam is gonna want gearing. I did a full N/A ls3 build and went with GM 3.91 gears. It was nasty for what it was. Not an extreme n/a build. But did 530whp. I am now running the same gears boosted.
More to come. |
09-27-2022, 10:09 AM | #10 |
Black SS-10 thanks for the post. I’m really liking the idea of gear change. And if I ever got a wild hair and went with a SC it sounds like I would be good to go with gearing. My car while it only has headers , CAI, pulls good, can’t imagine with gears and cam.
09-27-2022, 03:17 PM | #11 | |
SomeguyK
More to come. |
Thread Tools | |
