08-27-2018, 08:00 AM | #1 |
Drives: ISO ss 1le Join Date: May 2018
Extended Silverado Studs with spacers
Hi guys, I wanted to reach out to those of you running the Silverado Studs on your cars. I will be running a 5mm spacer for clearance up front with my Apex wheels.
I see some of you all are running either APR, or the longer silverado studs however the silverado studs does not look like it has the same knurl Diameter as ours. The camaro has a 16.01MM Knurl, where the silverado studs have a 15.70mm Knurl. Now, do i doubt that a .31mm difference will make a difference? No, but i wanted to check to see how they have been fitting. With that being said, you could potentially use a GM 15734261 (dorman 610-435.1) , which uses a 15.96mm knurl, and is the same length as the camaro studs, but the threads come all the way to the tip, which looks to be about 14mm (27mm vs 41mm) worth of extra thread. These are for the 3500 trucks. Just bouncing ideas. https://www.dormanproducts.com/p-159...origin=keyword Last edited by Move_Over; 08-27-2018 at 08:50 AM. |
