Old 08-02-2011, 12:27 AM   #1
Run and Gun
Run and Gun's Avatar
Drives: 2011 1SS/RS , 1966 GTO
burnt clutch?
My clutch has been kind of strange since I got my car. I keep smelling burnt clutch occasionally after taking off from a stop. Then tonight I took off from a stop and the clutch seemed to stick 2/3 of the way up and really started smelling burnt clutch and the clutch felt really different after that. Is the clutch ruined? I only have 1300 miles on the car so far,is this covered under my bumper to bumper warranty?
A machine for shrinking time and distance.
Run and Gun is offline   Reply With Quote
Old 08-02-2011, 10:54 AM   #2
Chris@SPMC
Drives: '99 H/C FRC Corvette and '07 TBSS
Depending on how you're taking off, slipping it excessively could be causing the burning smell or maybe it's the clutch still breaking in. How's the fluid in the master cylinder look? If the car is stock then I wouldn't imagaine you would have a problem getting it warrantied if there's a defect in design.
Chris@SPMC is offline   Reply With Quote
Old 08-02-2011, 11:24 AM   #3
Zachary Hendrix
Zachary Hendrix's Avatar
Drives: 2008 Z06 Corvette
Send a message via Skype™ to Zachary Hendrix
I seriously doubt it's defected. As you said earlier: slipping it excessively will begin to smell, but just when you stop at a light or when so... Sounds glazed to me.
TEAM LS7
'08 Corvette Z06 3LZ
10,363 Current Miles (9-26-2011)
3.8 Tested 0-60
8.02 @ 100.4MPH: 1/8 Mile
11.78 @ 120.2: 1/4 Mile
Zachary Hendrix is offline   Reply With Quote
Old 08-02-2011, 11:44 AM   #4
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Run and Gun, I would suggest having it checked to see if there isn't something wrong in the clutch if not for a repair then out of peace of mind. Eliminating the vehicle as a suspect would be a step in the right direction to getting this issue eliminated. I hope that helps you. If you continue to have issues with the vehicle let me know. Also in regards to your warranty question the bumper to bumper would have you covered for a fix like this under normal circumstances.
Jeff Morris, Chevrolet Customer Service
Chevrolet Customer Svc is offline   Reply With Quote
Old 08-02-2011, 12:08 PM   #5
Run and Gun
I'm going to drive it some more today and see how it feels. I really hope it's me and not the car.
Old 08-02-2011, 12:33 PM   #6
Run and Gun
What master cylinder are you referring to?
Whoops. I see now the brake master cylinder is also the hydraulic clutch reservoir .
Yes, the master cylinder is full of fluid.
Old 08-02-2011, 02:30 PM   #7
flem
Drives: old
hey run and gun , dont play around with that factory clutch, they are junk!! it will NOT get better!!! get a MONSTER CLUTCH kit and your clutch troubles are OVER. chris sent us one up here in mich, it was the best move we have made!! our car had only 677 miles on it. we got a level 3 love it!!
flem is offline   Reply With Quote
Old 08-02-2011, 05:33 PM   #8
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
I hate the clutches on the these cars as well. Lately, I had a ridiculously bad metal to metal grinding in the clutch area and am wondering about whether I should have it checked out. Eventually went away after a couple stops and starts but feel it's not completely back to normal.
My question is whether I'll be charged up the wazoo if they find it to be okay. Tried getting an answer from the uninformative desk girl and she gave me a general answer: '$100 for electronic diagnostic.' From what I know, the only way a clutch can be diagnosed is to take apart the clutch assembly. Will I have to pay $50/HR for it if they determine it to be fine?
edgehead2000 is offline   Reply With Quote
Old 08-02-2011, 05:39 PM   #9
racer-ex
racer-ex's Avatar
Drives: 2011 IOM SS
I had burnt clutch smell well over 2K miles until it got broken in, never stuck though.
<a href=http://www.sepa5.com target=_blank><img src=http://www.sepa5.com/wp-content/uploads/2011/08/sepa5-iom-black.png border=0 alt= /></a> <a href=http://www.sepa5.com target=_blank><b>SEPA5.COM – South East Pennsylvania Camaro Owners</b></a>
racer-ex is offline   Reply With Quote
Old 08-02-2011, 07:16 PM   #10
Run and Gun
Well so far today it seems like it's back to normal,no burnt smell either.
Old 08-03-2011, 05:09 PM   #11
Chris@SPMC
Glad you're lovin' it!
Old 08-03-2011, 05:13 PM   #12
Chris@SPMC
If it gives you any more trouble feel free to contact me and I'll help you out whether or not it has a Monster in it that matches your Synergy Green Camaro
Old 08-04-2011, 03:59 AM   #13
Bigslick440
Drives: 2011 SS
how much does a monster clutch kit go for?
Bigslick440 is offline   Reply With Quote
Old 08-04-2011, 06:18 PM   #14
Chris@SPMC
Depends on which model you're looking at, check out our website or call me and I can answer any questions you may have.
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 03:27 AM
clutch pedal repeatedly stuck, minimal load cab2g Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-26-2011 09:39 AM
What exactly burns the clutch on an m6? DarkneSS 5th Gen Camaro SS LS LT General Discussions 49 04-15-2011 10:55 AM
Clutch being replaced MillerTime V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 10-25-2010 04:37 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 10:40 PM
