03-13-2019, 12:57 PM | #29 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
FYI, that's actually on the C7 Corvette, not on the Gen6 Camaro. The latter has 100% throttle opening from 0 RPM available. Graph attached from my SS 1LE's stock mapping. ZL1 may be different, I don't have a ZL1 stock file.
03-13-2019, 03:46 PM | #30 |
Drives: like an old lady Join Date: Jun 2012
lugging is lugging. it applies to more than just the ltx. big truck motors for example - they make peak torque near 2k ft lbs at 1100 rpm. guess what happens when they’re driven and loaded frequently at those rpms. yes, they suffer egr problems (if applicable) and deposit build ups. there’s more to an engine than numbers. some of you get it, but it appears most don’t. as i said before, we can explain it but we can’t understand it for you.
03-13-2019, 04:24 PM | #31 |
Only 3k rpm? Lol, my '90 Miata was turning over 4k at 70 mph.
'16 Camaro 1SS
03-13-2019, 04:39 PM | #32 | |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Ryephile said WOT at idle in 6th is fine. Sent from my iPhone using Tapatalk |
03-13-2019, 05:15 PM | #33 |
Hot Dog
Don't fabricate falsehoods. I didn't say that.
03-13-2019, 05:16 PM | #34 | |
Hot Dog
03-13-2019, 05:56 PM | #35 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Ryephile is a complete idiot imo. |
03-13-2019, 06:12 PM | #36 | |
1>4 skip is active as low as 16 mph and the blocker retracts around 20 mph in the SS. Best mpg tends to be lower rpms/higher loads. EE vids do a good job explaining it, and I agree it's about what an auto does as the OEM is trying to maximize fuel economy, at least if the trans is in standard mode vs a performance mode that may discard fuel economy entirely. https://youtu.be/iNspNdVkslA The gearing in the SS and ZLE tranny is different, it's more like a 5 speed with a 2nd overdrive gear while the ZLE is more like a normal 6 speed manual. SS and Zl1 have about .75:1 and .5:1 5th and 6th while ZLE 6th is about .75, if I remember right. Anyways, in my SS I can shift into 5th as low as about 38 mph so that would be the same for 6th in the ZLE. You could easily do a 1>6 shift, lol... |
03-14-2019, 09:27 AM | #37 | |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Lugging
Shifting to 6th at 50 mph isn't driving for "fun" or because I "feel" good it's to avoid an obvious annoying amount of vibration and noise. I like to keep my rpms as low as possible unless I'm purposely getting into it, but those 45 mph noises and vibrations are annoying when one is listening to music or conversing with a passenger and easily avoided by shifting to 6th 5mph or a couple of hundred rpms later. I agree with your data based statement that the engine is rated and designed to perform from 1k rpm to 6+k, but there's also plenty of things that manufacturers make that are designed to perform to a certain standard that still have optimal operation practices in the real world for longevity.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
03-14-2019, 09:36 AM | #38 |
Rpm
My nb Miata does the same thing lol.
03-14-2019, 10:26 AM | #39 | |
Drives: 21 SS Join Date: Oct 2017
Damn, anything over 50mph and I'm in 6th.
03-14-2019, 10:54 AM | #40 | |
It's shockwaves going through the bottom end of the motor and is very bad for pistons, rods and engine bearings. It's a result of insufficient piston speed after ignition, when the air/fuel charge is detonated by the spark plug it wants to expand, and if it can't push the piston out of the way fast enough you get that sound and vibration as a result. Some motors are more effected by lugging than others, i.e. air-cooled VW motors hated it and American V8s tend to be more difficult to damage by lugging, but it's possible and the owner's manual warns against it specifically. |
03-14-2019, 11:30 AM | #41 | |
Revs
03-14-2019, 11:47 AM | #42 |
Drives: '18 1SS 1LE Join Date: Sep 2017
To me the whole 1-4 skip shift thing is the definition of lugging, too high a gear for the vehicle speed.
The few times I let it happen I wasn't happy with the results, I would intentionally shift earlier or later into second just to avoid the forced 1-4 shift. If I got caught by the skip shift nanny I would just go to neutral and then go for second. PITA Then I just got the eliminator.
'18 1SS 1LE Black, PDR
